Aikido / Buffer
Unfortunately, I find very little information about Aikido, as an output stage for the DAC (directly to the power amplifier), which I would like to build in balanced version and which has an impedance < 100 Ohm at the output, so to speak in buffer function. I found a table (attached) in the Broskie documents, in which some constellations appear, which make this possible. But approximately only with 9-pin tubes. For octal tubes, which I would like to use, only the type 6AS7 is to be found (B+ 100V), which however is accompanied by a very high current (Ik 100mA).
Can anyone tell me if there is a range of values that makes it possible to use octal tubes? With: B+ of 150V, lower Ik value and Zo < 100 Ohm. Otherwise I have to start with Noval tubes. But again, I can't find any values that would meet the requirement.
Does anyone have a tip?
The practical solution will follow theory.
A power amplifier will likely have no lower than 5k ohm input impedance, but let's say yours is something very unusual and has a super-low input impedance of only 1000 ohms
According to theory, the ratio of source to load impedance should be 1:10. Down to 1:5 would be fine as well, but since you want the output impedance of your source to be as low as possible, let Zsource:Zload = 1:10.
Zload = 1000
1000/10,000 = 100
Zsource = 100
From your Aikido preamp, Zout = 100 ohms should do ya.
Zout for a cathode follower should be about 1/gm
Choose your output tube to have gm of 10mA/V at the chosen operating point.
A high gm twin-triode will do that for you. Use 6DJ8/ECC88, 5687, 6N6P or 6N30P with a healthy amount of anode current and you should be happy.
🙂😀 :cheerful::cheers:
I think someone somewhere said that a pentode makes a better current source and a better cathode follower than a triode. So, because the second stage of the Aikido amplifier is a combination of a constant current source and a cathode follower, wouldn't it be better to make the cathode follower stage with a dual pentode?
