California Audio manuals are nearly impossible to find.
The successor companies refuse to support these older
products and there are two former service centers, one
in NYC and the other Chicago, I think, but both absolutely
refuse to even sell schematics. I tried many times. with
various CAL products I have owned. I finally was able
to get schematics for their DElta transport, but through
a repair shop and it took the owner 4 months or so
to get a schematic from them for an item he was
repairing!
In the case of lighting, you can probably open it up
and diagnose it yourself without the manual.
Michael
repairing!
Michael
Hi, I am in need also of the Aria Mk3 service manual. Anyone can help please?
- I replaced the drawer rubber belt and now the display is all disappeared
- Only one channel sounds
- There are 5 optical links from the digital board to the analog board, the first one U11 does not light up.
Many thanks for suggestion or help.
HiI am Italian.I have the california audio labs aria mk3 and the display have truly low lighting system.where it is possible to find manual of service in order to repair it?
zaba
Did you find the service manual and what happened to the CD player?
Saluti
Dennis
Hi thereJust repaired a Cal Labs Aria MKIII with factory mods. Have original box, packing and remote. Sounds great, working fine. Display dim. Looking for a good display, service manual, display part number or cross to Technics model number for fluorescent display.
Still using the cd player?
Dennis
what happened at the end? Did you repair the cd player? Sei riuscito a ripararlo?
HiHi I have the same problem,did you fixed your Aria?
thanks
What happened at the end? Did you fix the cd player?
HiJust repaired a Cal Labs Aria MKIII with factory mods. Have original box, packing and remote. Sounds great, working fine. Display dim. Looking for a good display, service manual, display part number or cross to Technics model number for fluorescent display.
Did you manage to fix the cd player?
Tx
Dennis
- Digital Source
- California Audio Labs Aria Mk3 service manual
