Need some advice please fm-300A
can someone advice me on how to calibrate the bios - trim on these amplifier boards .
I have built the the amplifier into separate chassis all is working but they are pretty much stone cold unless they are driven hard. what component do i need to measure across and to what value
thanks
here is a photo of the amplifier in question
Blue trimmer in front of the middle transistor on the radiator 🙂
This amplifier is class AB (B). It shouldn't warm up without a signal. The fuse must be installed in both power rails.
attachment.php
One pair assembeld Class AB Power amplifier board base on FM-300A amp
The default price included 2 channel assembeld and tested amp board
works voltage: Recommned +/-DC45V
Transformer power recommend above 300VA
Output power: 80W +80W at 8ohm
150W+150W at 4ohm.
Run it as intended class a/b
Do those to-3 metal can transistors have thermal compound on both sides of the mica insulators?
It takes a while for the heatsinks to warm up check bias after warmup
That to-126 pkg with the thermal pad, if the part has no exposed metal it does not need the insulator, remove pad and just use some thermal compound
after a evening of messing around with the amplifer board the only component the trim pot changes in the small device labeled 3090 its the small blue device close to the trim pot and i have trimmed them both too 250.0 mv
does anyone know what is the correct value please 😀
the 0.22 ohm resistors does not change with the trim pot
