Stereo 35w + 35w hybrid valve/tda7376b audio power amplifier
35w + 35w into 4 ohms.
Have a couple going spare.
Requires valve (12au7 or 12ax7), heat sink and +/-18v power supply.
£19.99 each + p+p
p+p is £4-20 to UK and £12.99 Europe and £17 rest of world.
I would be interested in a pair. Do you have a schematic also available?
I also have 2 mono pcb's if you would prefer.
Circuit is pretty basic, cathode follower valve stage into TDA7376B stereo chip amp. It uses negative supply and positive supply for valve B+.
Heaters are dropped off positive supply.
Requires +/-18VDC at 100VA.
Heatsink for TDA is also required.
Hey Nigel, any recommendation on a suitable (preferably low cost) power supply for your board?
I dont think you can get low cost power supplies now.
Transformers are expensive and SMPS isnt so cheap either.
On my JLH1996 I used a £10 20 watt SMPS and that works fine.
The hybrid valve amps I have designed seem to upset SMPS.
When I tried the 20 watt SMPS with my TDA7376B hybrid amp the power rails bounced a few times on power up. Even with a separate supply for heater it still clicked a few times through the speaker.
The 1000uF caps on the amp upset the SMPS and the valve heaters are low Z on power up so dont help.
