Serious about nano-Volts
I found this Keithley 140 Nanovoltmeter a few years back. Power cord was cut so I removed the battery pack and just put the meter on a shelf. Keithley was just down the road from where I drove a forklift at the die casting plant in college -- about the same era in which this instrument was built!
Just took off the cover, thought some folks would like to see the innards.
I still have my 610C electrometer but lost the special input cable. Years ago we bought their fancy electrometer with external box for the DUT that had a sapphire disk insulator. The schematic showed some proprietary MOSFET on the input with 2 back to back 1N914 diodes as protection. That was as funny as Barrie Gilbert on old Tek schematics as W(wizzard)101.
Keithley used to have a panel meter customization facility above the Pioneer Standard Electronics store in CLE -- they invited our ham radio club for a demonstration.
I purchased a Keithley 181 for a song back in the rubble of the dot-com crash. Works like a champ. The connector is the same for the 140.
The engineers at the top instrumentation companies were some of the best I ever met. I learned so much from working with the guys at Genrad, Tek, Fluke, HP/Keysight etc. Looking inside a 7 1/2 digit DVM is a wonder.
I remember one time when I was working in the medical electronics field, I was using an ESU (electro surgical unit aka RF knife), I forget who made it (>40 years ago). I looked at the schematic and I cold not begin to figure out how it worked. I later met the designer and told him that, he said "oh you'll never figure it out from the schematic, that has almost nothing to do with the way it works!".
Speaking of high sensitivity I found this in my collection of oddities. Its an optical galvanometer with a 300nA/mm sensitivity. With its 500 Ohm coil that's 150uV/division. These were used before DC amplifiers with enough sensitivity and isolation were available to look at very small voltages, usually in standards labs.
I need to figure out a use for this little number. . .
Remember the movie "Madame Curie" (Greer Garson and Walter Pidgeon, 1943). Marie and Pierre using an optical galvonometer when they were extracting radium from pitchblende.
A little known fact, Jim Williams owned Lord Kelvin's optical galvanometer.
