Greetings Fellow tube heads,
I just found a pair of Mullard branded EL 37 tubes and wondered if they could be substituted in place of EL34s. I have a Boyuu A9 SE UL amplifier which I built from a kit. Has anyone tried this? Why not try them and see for yourself I hear you ask? Because I want to check they are ok on a tube tester first.
I would very much appreciate any opinions about these tubes. I've just noticed there are some threads about this tube so please excuse my repeating the query
Kind regards
Kind regards
Joined 2009
“just found” ?
I see that these EL37 tubes are like hen’s teeth, if they are in good condition then they are worth serious coin.
I would pair them up with the owner of an amplifier that was built to use them from new.
I have got a pair of such amps and replacements are a right pain to get.
Agreed, I found a pair of 70s Mullard EL37, and sold then on to someone looking to use them in their amplifier.
They *were* a matched pair, that still worked, but I had no emission or gm measurement kit, so I set them in auction for a low starting bid of £10 for the pair.
I ended up getting over £280 for them, and a thank you email from the Japanese buyer, which was very happy with them.
So they must have been in almost new nick.
I also have a random KT61 if anyone would like that? 🙂
Checking them on a tube tester does not mean they could be ok to replace EL34. Unless you explicitly know how to bias and operate them in the particular amp you have in mind, such that they don't get stressed, then you take the risk.
On a related issue, I believe the EL37 has a mu of 9 in triode - similar to an EL34 which is 10.5 I believe.
Does anyone know which of the EL series had a larger mu? Like around 15 for an EL38, or around 18-20 for EL33 and EL12?
Any others in the EL or KT or other series that had a mu of over 10 in triode, like KT61? Wondering about 4654 for instance.
From what I read of the EL36, it's unsuitable for audio. Apart from ingenious stuff like screen drive etc. I was thinking of the usual topologies.
Please look then what Phillips did with the amplifiers EL6405, EL6415, EL6425, EV4411, EV4415, EV4417, EV4435, EV4437, etc. etcFrom what I read of the EL36, it's unsuitable for audio. Apart from ingenious stuff like screen drive etc. I was thinking of the usual topologies.
KT61 is an interesting valve in itself. I have a early ish Mullard one, If I recall with Marconi M-OV label, brown bakelite base.
It's a pity they're so rare, I only have a single valve.
Since it's worth nothing as a single valve, I might as well throw it in my 6P6S amp, it likes a similar OPT similar supply voltage, and maybe will give me another 0.5 W for the lab mono sound system!
As with almost any other sweep tube, limited to not suitable at all in pentode SE, but suitable in triode or screen drive SE and all PP modes.From what I read of the EL36, it's unsuitable for audio. Apart from ingenious stuff like screen drive etc. I was thinking of the usual topologies.
Take care: There has been another EL36, made by Mullard, without top cap, which is completely another tube!
Best regards!
I have noticed a few KT81s on my favourite local auction site - a KT61 in a Loctal base.
I see this is an old thread but in case anyone is still interested I’ve been using EL37 tubes in my Marantz 8 for a couple years. The sound is great. The amp is wired for triode. Since the EL37 max power is less than the EL34 I backed the bias back some. I don’t hear a lot of difference in between the two except the EL37s seem to open up after about 15 minutes running. The 37s look really nice on the amp and I get a nice blue glow. The cage won’t fit over the 37s but I don’t use it anyway.
As far as I see it from the datasheets, EL37 isn' too far away from EL34, if any at all. Plate dissipation rating is the same, screen a bit less.
Best regards!
Best regards!
Here is some more info from the valve museum.
http://www.r-type.org/exhib/aad0111.htm
Here is the entrails of a broken one.
http://www.r-type.org/articles/art-057.htm
Thank you! Valve musem states what I had supposed: EL37 was the predecessor for EL34, which followed six years later and was of considerably more modern construction.
Best regards!
Best regards!
- Tubes / Valves
- EL37 Tubes
