Inifinite Baffle
I am building a new home, and will have a dedicated media room approximately, 22' L x 18' W x 9' H.
I have a pair of Theil Smartsub 1.12 drivers I bought at their liquidation auction, and was considering building new enclosures, but was wondering if anyone has had any luck with IB's. I am going to build an interior wall 2 feet from the basement wall for my screen, and was thinking this might be a good area to put the subs.
The space would be approximately 2'dx18'wx9'h.
Any ideas, comments, or reference material would be appreciated.
There is a forum that does just this topic - the cult of the infinitely baffled.
Home | "Cult of the Infinitely Baffled" Hear The Bass, Not The Box The definitive online resource for Infinite Baffle subwoofer design Established 1999
I've made one IB, where I housed 4*15" woofers in a simple flat brick and MDF manifold that was squeezed into the corner of the listening room. I had the rear of the drivers firing into a large enclosure in another room (the large enclosure was a bed platform: brick walled and a metre high, to provide solidity and a lot of of volume for the sub).
4 cheap (high Qts) drivers + corner loading = lots of bonus SPL.
Compared to one (relatively expensive) driver in a normal box, this means you need 1/10 of the power.
IMO this was a nice, cheap, space efficient (space in the listening room, that is) and energy efficient way of building a sub.
One caveat: the roof of my large enclosure was (if I recall correctly) 16mm MDF framed with 5*10cm structural pine, and I was surprised by how much vibration I could feel, at moderate listening levels.
I put down lots of extra timber and mass (a layer of concrete) to reduce this.
TL;DR -
IBs are good. My tip, particulaly for a timber house, would be to build with opposed drivers to reduce structure vibration. You don't want a wall to buzz whenever there's a low note.
e.g. Infinite Baffle Subwoofer
...and I was surprised by how much vibration I could feel, at moderate listening levels.
A very judicious remark. Yes, important to distinguish between "feel" and "hear".
After using quarter-inch plywood for a labyrinth, I had to question my long-held belief in solid cabs with lotsa bracing.
For the OP's design, I think important to choose a driver with a suitable resonance to tailor the sound with a nice low boost for free. With IB, the spec is what you get.
B.
There have been a few long and entirely scholastic (AKA theoretical) arguments about making cabs rigid. Lots of precise measurement of wall motion but little evidence about audibility.
GM - my labyrinth walls vibrate plenty. Sounds and measures like a great sub but maybe better if I had made if from a concrete 17-foot sewer pipe.
B.
Within its BW? HF is a damping issue. In my main career I repeatedly proved that making structures 'ring' well above its working vibration BW was a far more efficient way Vs mass loading to push it below it. Be thankful they do/did as a lot of them are still in service at nuclear power plants, including sea going ones.
GM
