Hitachi HMA-7500 Idle current issue
Hi guys,
I'm recapping a Hitachi for a friend. The amplifier was working fine so I took it on. After recap I went to adjust and found the old bias pots are faulty so I replaced them. But now although the bias has dropped from 330ma to around 170ma. The service manual states 200ma.
The problem is when I adjust it, it doesn't make any difference! I checked a few resistors around the pot and a few Zener diodes and they are fine.
Any advice would be greatly appreciated.
Thats pretty much same circuit as Hitachi lateral mosfet data sheet.
Bias current is checked by removing B+ fuse and putting multi meter across the fuse on mA setting. I am pretty certain it was 100mA bias current.
100mA is standard standing current for a lateral mosfet.
200mA would be for 2 pairs.
Yes, it's Sampei's schematic. It even found its way into IEEE papers in the 1970s; and it was used in large numbers of amplifiers for years after that.
100mA is approximately the Zero-TC current, so the idle current should preferably be a little higher than that. The ±0.8V bias voltages suggest that they really did mean 200mA, so I would stick to that.
Measuring the bias voltages is the first step.
Wowzer this thread was getting very complex!
Its fixed! must have been a bad solder joint!!! put transistors back and touched up a couple of bad looking connections and measure again just to make sure I didn't do more damage and it was fixed!!
Thanks a lot for the very helpful input!
OK another problem.. I adjusted the output DC to around 0mv. When switched on the voltage is -80mv and climbs up to around the 0mv set by the pot when I guess it gets warm.
I assume Q701 and Q702 which are 2SA872 are at fault?
Brand New elcos are also leaky. They need a few hours at least to polarise fully, and then the leakage calms down. I assume you have used a bipolar elco?
Given that it's only 4.7u, you could easily switch this one to an MKT{POLYESTER, MYLAR} or MKP. Even low cost ones will be much better performance than elcos, and all have effectively zero leakage. OTOH, Small size elcos get stale and leaky in no time.
