Shanti Dual LPS 5V/3A , 5V/1.5A
Hello,
any news on the amp? I don't want to be a nagger, but the initial rumours had the premiere date as far back as the end of 2019. A possibility to purchase it before Christmas this year in EU would be excellent, but I don't know if it's realistic or too wishful. Also giving an approximate price range - if possible, would be greatly appreciated.
Best regards and stay healthy!
We are talking completely new design in order to take full advantage of PCIe 2gen connection . Expect lots of changes
Sounds like your pretty early in development.
Not sure if you have thought of these, but probably have:
Have you considered a master clock input, for those that have better oscillators than NDK? That's my biggest issue with current USBSig
Have you thought about using a clock for Ethernet and a separate clock for USB
Have you considered doing a PCI-E card format for output so it could support the X86 platform too?
Are you looking at the latest ASmedia chip for USB?
Have you considered using LT304* regs?
Have you considered adding galvanic isolation for USB and Ethernet so that we can power it by separate rails or use jumpers for those who want a cheaper build? Three rails - USB, Ethernet and PI4
Oh basically HDMi is used as the connector only as it's cheap, and reliable way to transmit i2s signals via LVDS, here's a spreadsheet with various Dac's and USB/SPDIF i2s on how the wires are connected, and their various standards if you are interested.
Most use dip-switches to support multiple standards.
i2s - Google Drive
RPI i2s signal is not good. I will not provide output. Also take in consideration master/slave DACs
No worries you have all other outputs when combined with Digione Sig
Amp is advancing . I am posting my latest test data FFT at 10W 8R 1Khz unweighted
THD is at 0.00016 !!
THD+N at 0.0007
I had to sacrifice some of the noise on the output, but I have a new idea (PCB) and will try it..
My dual LLC is working and ..not. On one PCB its working fine , on new PCB is still unstable due to feedback (I dont like feedback circuits). I might have to migrate to old PCB since its stable to 225W
So please have patience. I am ordering new PCB (and hope they are final)
Just so you understand...this new AMP is designed for audio quality . The most important parts (except for THD and ours is ultra low ) are inductor , caps and output noise . I have worked (many hours of styding and reading) with a manufacturer and designed my own inductor !!! All for audio quality.
Question . How do you defeat magnetic hysteresis...feedback right ? Hehe..nope.
... I have worked (many hours of styding and reading) with a manufacturer and designed my own inductor !!! All for audio quality...
Sounds interesting. I just read a little from Bruno Putzeys paper on this. You inductor could be using a laminated core or iron powder core with Litze Wire? Just my armchair guess - from a chair without armrest 😀
I have no timeline. I have started the design and will bring it to the market .
Lots of new ideas on the power , this time discreet . Not only they show lower noise than LT304x but they are also incredibly low impedance .
PCIe slot will be provided (one extra)
We expect to need a beefy PSU , 2.5A for RPI4 and then for PCIe , depending on what you got attached to it , at least 1A (if you have SSD) or even 3A of you have a power hungry device.
