Yes we are already working on RPI4 CM
Are we talking USBridge Signature on RPI4 CM?
We are talking completely new design in order to take full advantage of PCIe 2gen connection . Expect lots of changes
This sounds very exciting! Would the new solution still support Digione Sig or have some kind of SPDIF output for those of us who don't have or want USB?
Hello,
any news on the amp? I don't want to be a nagger, but the initial rumours had the premiere date as far back as the end of 2019. A possibility to purchase it before Christmas this year in EU would be excellent, but I don't know if it's realistic or too wishful. Also giving an approximate price range - if possible, would be greatly appreciated.
Best regards and stay healthy!
Regarding the amp , I have no date for releasing . Regarding pricing , it will be rather low compared with any best class D.
Nanekiu I am not familiar with i2s on hdmi
Oh basically HDMi is used as the connector only as it's cheap, and reliable way to transmit i2s signals via LVDS, here's a spreadsheet with various Dac's and USB/SPDIF i2s on how the wires are connected, and their various standards if you are interested.
Most use dip-switches to support multiple standards.
i2s - Google Drive
i2s - Google Drive
Sounds like your pretty early in development.
Not sure if you have thought of these, but probably have:
Have you considered a master clock input, for those that have better oscillators than NDK? That's my biggest issue with current USBSig
Have you thought about using a clock for Ethernet and a separate clock for USB
Have you considered doing a PCI-E card format for output so it could support the X86 platform too?
Are you looking at the latest ASmedia chip for USB?
Have you considered using LT304* regs?
Have you considered adding galvanic isolation for USB and Ethernet so that we can power it by separate rails or use jumpers for those who want a cheaper build? Three rails - USB, Ethernet and PI4
Yes yes and yes. No to master clock it makes no sense to me.
No to USB galvanic isolation .Galvanic isolation on Ethernet as usually + extra filtering .
I am using better than LT304x .Discreet.
i2s - Google Drive
RPI i2s signal is not good. I will not provide output. Also take in consideration master/slave DACs
No worries you have all other outputs when combined with Digione Sig
Amp is advancing . I am posting my latest test data FFT at 10W 8R 1Khz unweighted
THD is at 0.00016 !!
THD+N at 0.0007
I had to sacrifice some of the noise on the output, but I have a new idea (PCB) and will try it..
My dual LLC is working and ..not. On one PCB its working fine , on new PCB is still unstable due to feedback (I dont like feedback circuits). I might have to migrate to old PCB since its stable to 225W
So please have patience. I am ordering new PCB (and hope they are final)
Just so you understand...this new AMP is designed for audio quality . The most important parts (except for THD and ours is ultra low ) are inductor , caps and output noise . I have worked (many hours of styding and reading) with a manufacturer and designed my own inductor !!! All for audio quality.
Question . How do you defeat magnetic hysteresis...feedback right ? Hehe..nope.
THD+N at 0.0007
Sounds interesting. I just read a little from Bruno Putzeys paper on this. You inductor could be using a laminated core or iron powder core with Litze Wire? Just my armchair guess - from a chair without armrest 😀... I have worked (many hours of styding and reading) with a manufacturer and designed my own inductor !!! All for audio quality...
What's the timeline for USBridge Signature on RPI4 CM?
I have no timeline. I have started the design and will bring it to the market .
Lots of new ideas on the power , this time discreet . Not only they show lower noise than LT304x but they are also incredibly low impedance .
PCIe slot will be provided (one extra)
We expect to need a beefy PSU , 2.5A for RPI4 and then for PCIe , depending on what you got attached to it , at least 1A (if you have SSD) or even 3A of you have a power hungry device.
- Vendor's Bazaar
- Shanti Dual LPS 5V/3A , 5V/1.5A
