Perhaps a dumb question, but I hope not. Are the onsemi G versions an OK swap for the originals? I'm looking to repair some Lexicon amp boards and they each use four of each. Obviously I'm not going to find original MJ21194/3 parts. I presume I should change all of them on each board?
Thanks,
craigr
Thanks,
craigr
If you cant get originals you are getting on dodgy ground.
Some of the ebay/China stuff is poor quality and blows up if you fart near it.
I would suggest half an hour on RS Components website looking through transistor specs for replacements.
A wild guess would be MJ15003 and MJ15004 available from RS Components or CPC (Farnell)
TO3 metal can On Semi G variant is still freely available at Mouser and Digikey for these types - although not cheap. The MJL - G version in TO-264 is also available at about half the price of the metal can type.
CPC still do the G version a little cheaper than Mouser etc.
https://cpc.farnell.com/on-semiconductor/mj21193g/transistor-pnp-to-3/dp/SC06826?ost=mj21193
TO-3 MJ21193/4G are also available from RS components. Not particularly cheap.
As Nisbeth said, G is lead free, means "green". Seems all On Semi devices are G now.
Sweet, thanks for confirmation. Specs were identical so I was hopeful 😱G only means "lead-free", so there should be no change in the actual transistor.
Kind regards,
craigr
Didn't he ask about Onsemi parts?If you cant get originals you are getting on dodgy ground.
MJ15003/4 and MJ21193/4 aren't directly interchangeable. Check their Ratings and fT, please.A wild guess would be MJ15003 and MJ15004 available from RS Components or CPC (Farnell)
Best regards!
- MJ21194/3 to MJ21194G/4G
