2x EL84 Fixed-Bias beyond 400V, anyone tried this?
Yes EL34,s Vincebus not EL84,s.
But that is not the limit the EL34,s can be run at 800 volts plate --400 volts screen for a load of 11000 ohms .
I just have a very hard time accepting that high a voltage for a STANDARD EL84 , I think there is more going on I don't know .
Scott 299B. Not sure how it would like guitar duty, 430V, 420V at the plates. It also used the upgraded 6BQ5 - 7189. The picture does not seem to go full size so I included the link.
http://hhscott.com/pdf/sd/299B_3_4s.JPG
Yes, but some say a Russian 6P14P can be used as a substitute. I would just go to a bigger bottle but this is not what the thread asked for. Come to think of it, a 9-pin 12AB5 is used in a Harmon Kardon at 440V. I did a guitar amp with a pair running around 400V from memory.
No PCL200 ,the standard current draw for a pair of EL84,s in Class AB1 including the screen is ( approx) nearly 120ma , I always allow a safety margin as heating up transformers is not advised.
"Class AB1" and "nearly 120 mA" is vague. A pair could never idle (so no input signal) at 120 mA with Va = 450 V. So a reasonable explanation would be that you mean that the current at maximum power is nearly 120 mA.
So you at "nearly 120 mA" and me at "114 mA".
So than why the "No PCL200..."?
It looked to me that you suggested that the current demand on the power transformer at this anode voltage (450 V) is higher than at the more usual 300 V. That is, like I think you now also state, not the case.
The rest of the current demand depends on what else is running in the amplifier. A safety margin of 30 mA on top of that, looks unnessecary to me. But to each his own.
yup is a bass :p
Measured correctly, at max vol the B+ drops to 415V, with 1KHz 2V sine wave at the input got 14V RMS with a 50W 8 ohm dummy load on the output, 24.5W... got 35W full clipping
Meant that it was as expected. The sound is not that bad, one portion that was overloaded more than desirable but I thought it was usable in a live setting. Mind you depending on the setting.
Account Closed
Joined 2018
You will probably find difference in power gives minimal increase in sound power.
For twice the loudness you need 10 times the power as the ear is logarithmic.
I would suggest at least a 100 watt amp.
Most musicians I know tend to prefer solid state amps if used for bass guitar's, etc.
That way, they can supply the punch they sometimes want during a gig.
The voltage drop over R1 (now 1K) is V4 (now 425 V) minus the sreengrid voltage (300 V) = 25 V. So the current through R1 = 25 / 1000 = 25 mA.
The voltage drop over R5 (22K) is 300 V - 273 V = 27 V. So the current through R5 = 27 / 22000 = 1.23 mA (which seems too low for the three 12AX7's that follow).
This would mean that the two screen grids of the EL84's are taking 25 mA - 1.23 mA = 23.77 mA. So each screen grid is taking about 11.89 mA. So the screen grid dissipation per EL84 is 0.0119 x 300 V = 3.57 Watt (well over Pg2 max, and just under Pg2 max peak).
If you look at datasheets for the EL84, a screen grid current at 300 V of almost 12 mA per EL84 at idle is way too high. It should be something like not more than 2 mA.
