Woden Design Victor for FE166En
The back loaded horn contributes gain at LF to mitigate the need for BSC. Indeed, depending on room placement and amplifier (do the parents have a high output impedance amp to drive them?) you may actually need antiBSC (ie add some damping).
dave
I've started the enclusure
About the amp , it will be a SA300 SMSL ( they are 70+ YO and it's a present more than a perfect audio set up as they won't notice the not perfect set up with non expert 70+ years ears )
In fact they were totally in love with the FH3 Fe126En i made for my son and nearly asked ( shy attitude ... ) so ....
SMSL SA300 has a few corrections inboard , so when delivered at their home , i'll get Rew and see if in need any other correction
Beech 18mm pannels are in the cutting process at the moment , speakers and amp arrive this week ( prefered to plywood for cosmetic reasons ( my mother 🙂 )
I suspected as much. Doing that will degrade the horn performance. At each one of those 180° bend there is a bit of an expansion. This acts as a low pass filter.
If you put those in you will get to much HF out the mouth which will directly affect the response in the about 300-600 Hz range, and not in a good way.
dave
