Help Hifonics Z500D hip4080
The only output FET that I found to be universally reliable in the 4080 amps is the IRF3710Z (<< Z is critical). Even new FETs with the same exact part number as the originals would not work reliably.
Did you order a new 4080? I thought that you tried both you had and neither worked.
