How might a 6GM5 do tied as triode?
6GM5 is a 7591 in a bottle with 9-pin mini B9A base.
6GM5 characteristics are identical to those of 7591 and 7591A.
I'm sure if you do a search for 7591 in triode you'll find more info.
A friend of mine and I built a push-pull class A 7591-triode amp, years ago, using fancy Tango transformers. It sounded OK, but I think 7591 is better used ultralinear, not triode. But that's just my limited experience.
Attached is schematic and test results of 6P41S UL-PP amplifier I have done. It works fine with low supply voltage and is very linear (=low THD).
Power and THD-readings have been taken without GNFB.
  • 6P41S_PP_eng.pdf
    6P41S_PP_eng.pdf
Reactions: Marco audio
big thanks - but I botched the number. 🙁 - they are "6GB5" /EL500
The 6GB5 is a small TV sweep tube. The maximum screen grid voltage spec is 200 volts. My experiments with the 13GB5 said to stay at 250 volts or less in triode. There you will get 2 or 3 watts in SE. Running them in push pull pentode with up to 500 volts on the plates is a different story, there you can get 80 watts or more. I saw over 100 before the red glow of death appeared.
Hello,
First trial tonight .
I couldn't help but replace my dummy loads with my little Kef speakers. The sound is a little weak but you shouldn't expect anything powerful. the voltage values are almost the same as those I obtained with PSUD 2 (B+=268v instead of 265v).
The miller effect capacitance of a pentode is lower than the miller effect capacitance of a triode.
Your 6J52P pentode that is triode wired has more miller effect capacitance than when it is in pentode mode.
However, even with the 6J52P in triode wired mode (with the screen grid signal swing moving the same as the plate signal swing) . . .
A 1k stopper resistor will not affect the high frequency response at 20kHz.
Chinese transformers.
But they look not so bad.
4 c core iron : 23H 320R 5,3K
Perhaps i must weld a little capacitor on them (few pf).
But it's possible that the trouble comes from the whole wiring.(No chassis for the moment)
  • Thank You
Reactions: Ixnay
