The electrolyte is sometimes difficult to remove.
Check the entire audio section. It only takes a minute or so.
Were there any traces that passed near the terminals of the bad caps?
I use normally diluent to remove electrolyte. Yes, i have found electrolyte on 1000uf bad caps, i will check all audio section
No problem around all capacitors..
I have noted one thing, with 2.7 ohm lifted (bad channel), i have on pin7 of the last op-amp -13,15V, is normal or abnormal situation?
Did any traces pass between the terminals of the bad capacitors (top or bottom of the board)? The electrolyte can saturate the board and conduct below the surface.
It could be normal. Post the DC voltage on all terminals of the op-amp.
Pin 1:
Pin 2:
Pin 3:
Pin 4:
Pin 5:
Pin 6:
Pin 7:
Pin 8:
Pin 1:
Pin 2:
Pin 3:
Pin 4:
Pin 5:
Pin 6:
Pin 7:
Pin 8:
With or without 2.7ohm resistors lifted?Did any traces pass between the terminals of the bad capacitors (top or bottom of the board)? The electrolyte can saturate the board and conduct below the surface.
Pin 1:
Pin 2:
Pin 3:
Pin 4:
Pin 5:
Pin 6:
Pin 7:
Pin 8:
Pin 1: -0.06VIt could be normal. Post the DC voltage on all terminals of the op-amp.
Pin 2: -0.003V
Pin 3: -0,003V
Pin 4: -14,9V
Pin 5: -0,003V
Pin 6: 0V
Pin 7: +0,07V
Pin 8: 14,80V
If i lift the 2,7ohm resistors, on pin1 have 14V and on pin7 have -13V
It's already on the input to the last op-amp.
When you shorted the muting transistors, did you short 1-2 of the transistor itself or did you short the square pad to the center pad/terminal?
Pin1-2, drain with source pins.
I think.. but can be normal this pop? I have 3x orion amplifier, 240gx, 280gx and 250sx all with a pop on power on, this is strange..
Install a socket and try any op-amp you'd like.
Don't confuse a low noise figure with low turn-on noise. Better in some regards may not mean better in this application.
- General Interest
- Car Audio
- Orion 250sx with BJT on power supply
