Orion 250sx with BJT on power supply
Compare the readings of the output and driver transistors on one channel to the corresponding transistors on the other channel. Measure the resistance from leg 1-2, 1-3 and 2-3, using the same probe placement on both channels. Is there any difference?
No difference, same situation.
I have found difference on last op-amp output, without input signal, strange on pin1, pin7 is ok. What do you think? Measure in attached
Shorting the muting transistor should have blocked any noise that originated before it. Lifting the 2.7 ohm resistor should eliminate everything after it if there is no DC on the output of either channel. .
i have shorted both muting transistor but pop was present. with lifting the 2,7ohm pop is deleted.
The op-amp looked healthy but you might try replacing it
you mean the last op-amp?
