Alpair 7MS Cabinet Dimensions (Quick Check)
I've ordered a pair of 7MS's, and as a first 'proper' project, I'm building a set of desktops for low level listening.
I'm trying to do this pair 'right' - first time for everything 🙂, can someone check my measurements and tell me if I'm in the right ballpark?
I'm using the guide at diyaudioandvideo.com
The official speaker specs
877559d1600712701-alpair-7ms-cabinet-dimensions-quick-check-data-1-jpg
The enclosure calculator asks for a 'Fs' measurement. I've used the 'Fo' from the specs as it's the only one in Hz - is this wrong?
Putting those into the enclosure calculator tells me to aim for an 8.77 ltr box.
Speaker displacement I get at 0.21 ltrs
I know I want the speaker fronts 6" wide and 17" high. Using 3/4" stock and no bracing, that means the box is 9.36” deep
So 6"x17"x9.4" - does that sound about right?
Thanks 🙂
I am currently working on the A7ms miniOnken planset. The optimum volume i am using is 9 litres. It turns out that the volume the driver takes up is pretty close to exacty the extra box volume you get from chamfering the back of the driver cutout 45°.
6"x17”x9.4” with ¾” material yields 9.03 litres, just about perfect. I would suggest that with a box this large you may want a brace.
dave
I have done the 1st pass of A7/11ms boxes. Except for the millSize A7ms box all are 9 litres and the set does include CGR for both. While a larger box is not suitable for the A11ms, it may be possible to fit the A7ms in 13 litres althou the sim does not give quite as nice a shape it is very close to the Mar-Kel for the EL70 so i will do one if someone wants to build one. These 2 plansets are currently in beta so if you want to participate send me an email. This alignment also makes it suitable for the Compact FLoorStander.
The current beta testers plan on doing the full on trapezoid for the A11ms, and the milliSize for the A7ms. Be nice to get a couple other builds particualrily for the A7ms which has a wider range of boxes.
Hi, has the CGR been finalized for Alpair 7ms?
I need a slim enclosure for a smallish room and I think the CGR is the way to go, a file seems to have been posted by Dave in this thread but doesn't show anymore, and frugal-phile.com only has CGR for 7 and 7.3, but now 7ms is the only version largely available.
Thanks for all the info that I've already been able to gather on this forum 🙂
