Parasound HCA-2200 flatening sinewave at ~10W
I'm working on a Parasound HCA-2200 (MKI). It is flattening the bottom of the sinewave in both channels at the same time, around 10W.
I've recapped the unit, except for the main filter caps. Someone had done a partial recap before. They had added an electrolytic cap across D105/106 and 205/206. I pulled it and didn't note the value. Probably should have. Not sure if it was supposed to be there and they had botched the wiring of replacement RCA jacks so I wasn't confident in their work. And was trying to fix a buzz (which was because I still hadn't gotten the RCA jacks wired right). Could it have been there for this reason? EDIT: looking at pictures in another thread where the caps are there. Guess I screwed up not keeping track of them. Anyone know what value they might be? I could email parasound again I guess. EDIT #3: In the MKII schematic it looks like there is 1uF capacitance here.
Where should I start looking?
Are the two trimpots at the input offset settings? If so how do I set them since there is two? EDIT AGAIN: Post #7 answers (Parasound HCA-2200 problem - need some help)
Schematic attached. Only the MKII schematic was online so I emailed parasound and they sent the MKI schematic.
  • HCA_2200 (1).pdf
    HCA_2200 (1).pdf
  • Bias Settings.pdf
    Bias Settings.pdf
Into what load impedance?
Please post Volts RMS measured, then remove load (resistor/speaker) and measure again .
Same value as before or higher?
When output *just* starts clipping, in both cases, as now and without load, what do you scope on IC101 pin 7?
Measure supply voltage (pins 4 - 8) at IC101
Please post results.
Well, a new unknown variable was introduced.
I´d triple check each and every cap orientation, besides poor soldering, cracks, etc.
Maybe it was a Mod, but in principle amp should work fine with the .1uF cap shown there.
Your schematic shows .1uF , the schematic you are NOT showing may show 1uF, who knows? In any case that´s a servo amp, no big change expected from one value to the other.
See above.
Pretty confident. Tried the 1Khz signal from the signal generator, as well as off my ipad through a preamp just in case that was weird.
I've done lots of power tests before, not sure what I could have done wrong.
I realized that the amp has a 3 prong cord and I'd hooked the scope ground to - speaker terminal. But - terminal is grounded so that is okay I think. I need to watch for that though.
Not sure about your signal generator, but if it is an app, earphone out usually can´t provide more than 200mV RMS, insufficient to drive a power amp which typically need 1000 to 1400 mV.
If generator clips, of course that will show up at output.
If preamp is fed lowish voltage rails (say, from a 9V battery) it will also be compromised, to be certain you need a 10X preamp, a simple op amp stage, which turns 100/200mV from a phone or tablet into 1-2V RMS, and it should be fed classic +/-15V rails, in which case it can put out up to 9V RMS.
But let´s start with simple measurements suggested, as-is.
Hmm, Z101-102 are shorted in both channels so the input opamp isn't getting any voltage at all. This is embarassingly simple.
These zeners have 0.01uF film caps across them, as well as 100uf caps. How important is the value of the film caps? Schematic shows 0.1uF. They are twisted together so easiest to replace the film caps too.
I looked at the schematic for the II version to compare the value of the bypass caps I mentioned in the last post. It has the electrolytic bypassed with a 0.1uF film cap and a 0.01uF cap. Overkill? My understanding of bypass caps is that the value isn't overly critical, so I used some 0.027 caps I had on hand.
Originally, these caps were mounted right above the zeners, so the zeners wouldn't have as much room to cool, and they would cook the caps. I opted to mount the caps to the bottom of the board instead.
I also removed the 6 parallel 0.01uf bypass caps on each main filter cap and put one 1uf cap in their place. Another thread was saying to do this. They were talking about the II version but still seems relevant for this one.
Amp seems to be working good now.
