emi filters
Hello,
I am tested various emi filter on the market. And decided to design my own with trial and error method and get very good results better than commercial units.
You can find the test results unfiltered ac line vs my design filtered in the attached picture.
With my design, i got better noise figure than any commercial unit i tested and i tested more than 30 unit.
I am not an filter expert i just make lots lots of trial to find a good solution.
But after all these effort none of mine or commercial units not able to filter under 10Khz noise.
I am glad if any one know any solution or any comments.
I am not surprised a typical EMI filter is designed to remove/lower HF interference through a combination of inductance and capacitance by lowering the impedance path to earth.
If you can design a HF filter then use the same formula to design low frequency filter there is a standard formula for it .
Or are you using a "virtual helper " ?-- I am talking old school mental calculations .
I already did many trials but to get to filter such low frequencies would require increasing so-called leakage current to the levels that would a) require that the filter is permanently grounde b) can not pass CE certification rules and cause earth leakage breaker trigers.
Active filters ( in mains supplies ) inject , in the opposite direction ,the harmonics drawn by the load ,so that the line current stays sinusoidal .
While this is industrial power supply ( utility company ) related some of it could apply to your situation with variations.
Noise/distortion in a sine wave supply upsets the purity of the sine wave supplied.
I am not talking audio situations here just the power supply.
Hallo,
Ik ben getest met verschillende emi-filters op de markt. En besloot om mijn eigen te ontwerpen met de methode van vallen en opstaan en zeer goede resultaten te behalen, beter dan commerciële eenheden.
U vindt de testresultaten ongefilterde ac-lijn versus mijn ontwerp gefilterd in de bijgevoegde afbeelding.
Met mijn ontwerp kreeg ik een beter geluidscijfer dan elke commerciële eenheid die ik heb getest en ik heb meer dan 30 eenheden getest.
Ik ben geen filterexpert, ik doe gewoon heel veel proeven om een goede oplossing te vinden.
Maar na al deze inspanningen is geen van de mijne of commerciële eenheden niet in staat om onder 10Khz-ruis te filteren.
Ik ben blij als iemand een oplossing of opmerkingen weet.
