Eagle question
Yes class, not type.
Jan
I am quite sure that with net classes proper set even the autorouter would not try to route a 500V track between two smd pads. Before any routing
-Do spend much time on ultimate component placement
-Do setup your design rules.
For about 30yrs I do PCB-CAD now. Never touched any autorouter.
The problem is that the autorouter has no idea of voltage, of what '500V' even is ;-)
The thing to do is to assign the 500V line to a class 'highvoltage' and then set the design rule for class 'highvoltage' to say 20mills clearance.
Jan
I think you should not worry too much about board size at this point (yes I know I commented on it ...).
Try to get a feel for better layout. As noted, repetition makes you a master.
Example: in pic 1, rotating the transistor and moving it and the cap (?) that is at it's right lets you run that thin track between the cap pins.
In pic 2, it seems you have a weird track to connect two points that are next to each other.
Also, rotating both LEDs 90deg CCW will make the tracking shorter.
Jan
It is a little unfair .what takes you 2 minutes to do takes me 1 day....😎
Yes it is. Also that other stuff you didn't see, that is quite normal. I can't tell you how often I finished a PCB, being quite proud of myself, then looked at it a few hours later and ask myself how I could be so stupid ;-)
It gets better with every layout, especially when you start to learn the program and you are no longer distracted by cursing because you can't find the right command.
You're doing fine.
Jan
Following data using EAGLE 9.5.2 CAM-Prozessor are to supply for manufacturing:
- top layer (1)
- bottom layer (16)
- top stop layer (29): you´ve to drawn the outline again on this layer, width =0,6mm
- bottom stop layer (30): you´ve to drawn the outline again on this layer, width =0,6mm
- top silkscreen depends on components definition (layer 21, 25, perhaps 27?)
- outline (20)
- top cream (31) if you want reflow mask
- plated and non plated drill datas
No silkscreen information over electrical pads.
JP
MUCH better! But still some track width irregularities for N$1 at J1 and R2.
I would also recommend removing the part values, only leave the designations, and make sure no text is over the holes or too close to the holes.
Otherwise you will not be able to read it on the finished PCB.
Edit: also would be good if you could align the mounting holes with each other, helps with the holes later.
Jan
