Unity/Synergy horn tweeter-mid distance constraint
Danley's Unity/Synergy horn needs the mid and tweeter ports to be distanced within quarter wavelength of the cross-over point frequency. Which one of the "x", "y" or "z" represent that distance constraint?
Giri,
With digital time alignment, the "Y" axis can be corrected to exactly the same arrival time regardless of it's distance.
Ideally, the center to center distance between the ports, double the distance of your "X", and the "Z" distance both should be within 1/4 wavelength for the best polar response.
As the distance is increased past 1/4 wavelength, off axis polar response will suffer.
That said, when using conical horn expansions, off axis polar response is never quite ideal.
Art
  • 1:4 Wave.png
    1:4 Wave.png
Giri,
Art
I thought over your 2X distance constraint. I wonder if Danley's own products would confirm to that constraint.
That depends on the shape of the roll off on the drivers in question. My mids can be crossed over with a 4th order slope on the lowpass using most of the slope of the null to do it. If I wanted to do the same on its highpass I would have to use a 6th order slope.
Rob.
