Ressurection, repair, restoration and modding of a Marantz CD273
So just got hold of a Marantz CD273, very cheap, DOA (wouldn't do anything when switched on). Turned out to be the voltage selector. I decided to take it out completely and hardwire transformer to 240V. Immediately the player was back to life. BUT: it wasn't recognizing the CD.
So, first things first and safety always: made a little movie of the laser with my mobile phone. Argh... NO red dot! But I've heard, read and seen enough related to the infamous blue C2103 33uF Philips cap so I stayed calm and got the soldering iron and exchanged the cap with a fresh normal 33uF radial cap. Hooked it all up and tried again... tada! red dot was there!! 😀
Inserted CD, got TOC a couple of times, other times it failed. Playback was failing at the middle of disc. So, now that laser was back to life it was time to do the usual servicing - cleaned the lens, also the inner lens, was all very dirty. There I had two surprises I didn't have before with any CDM mechanism: the screw on this one has a nut on the other side which always falls out and is a real pain to put back in! The other surprise was a little thin whitish plastic piece that suddenly appeared no my desk as a left over piece when lens case was back assembled together. I didn't like that. And yes, the result was bad: although lens was shiningly clean and laser working fine (I also adjusted laser voltage, was at 65mV, put it back to perfect 50mV), the mechanism was making a weird noise when reading past track 1 and started to fail and skip badly at every CD from the middle onwards. I decided to investigate that little whitish plastic thing. I reopened the lens case again and discovered another of these plastic things beneath the upper half. So I figured the other one would be on top, yes, there was a glue mark, it had simply fallen off due to age! 😱 I got superglue and put a real small drop and glued the plastic thing back to its place. Reassembled (with the nut falling out so many times...) and tested. Incredible, the noise was gone, how's that even possible, that plastic thing can't weigh more than 0,5 g??? I'm not sure if it was the cause, but the problem was gone. Now, player was playing normally most CDs, but failing sometimes suddenly towards end of disc or not reading TOC. Audio was great, btw, even though I haven't changed caps on mainboard yet.
Decided to change remaining electrolytic caps on CDM servo board to new ones. Then noticed that it's an older version of CDM2-board, with the focus potentiometer. So had a look at service manual, states that this has to be adjusted measuring 400mV on a certain test connection (across a cap). I found out that this is a real tough adjustment (I guess they had a special test disc) as the voltage fluctuates! In time and depending on where the track is! So, I ended up doing a lot of trial and error and managed to find a kind of sweet spot, it's not really 400mV, but it fluctuates between 220 and 450mV, depending on disc poisition. Now it was working nicely, really quick TOC (about 2 secs) and track change, no skipping during playback at all, silent laser while playing, but still sometimes it was failing to read TOC or simply stopped playing when close to end of disc. But only rarely. Left it playing a whole CD (a CD-R), which was played flawlessly and sounded great.
I decided to repair the drawer (was stuck and belt was almost gone), put a replacement belt and lubricated all gears with silicone lubricant, got it back working, then also did a good clean to the whole CDM mechanism, that's when I noticed that after all seems to be a CDM4??? Now this is weird. I once repaired a Philips CD150 which had a CDM4 laser fitted to a CDM2 mechanism and drive, as probably the laser had died. It had the update of components that's described in service manual but the label clearly stated CDM2. Also, the lens cover didn't have that horrible nut falling out. This one, on the other hand, has the oldest CDM2 servo board (the one with focus adjust), the laser really looks like CDM2 to me (but might be mistaken, as board does have some components soldered in afterwards), but the drive tray has label stating it's a CDM4??? Also the player supposedly is CDM2 originally, as can be found on net. May I assume this has been repaired with a new cdm4 drive which is a mix of cdm2 servo board and cdm2 or 4 laser? That doesn't make much sense, does it? Or did they simply put the sticker of new CDM4 laser on the drawer which is the same as original, from CDM2?
Now comes the most interesting part: after all this, I decided to further test it. Now it never failed again - read every CD I tried, even old blue CD-R with quite a few scratches and very badly scratched pressed CD. Great!! But why was it failing occasionally before?
Maybe some parts, like radial servo, needing to be used, to move, so to get "free" again after having sit non used for so long time? I did in fact noticed a slight "eek" when radial arm was moved.
Or can this be another case of "warm-up"? Maybe the infamous griplets which were the cause of failure reading discs in the cd150 I serviced? Yes, this also has them on mainboard. It's very similar to Philips CD-150, although with much nicer front panel and display and digital out.
I'm going to put new electrolytics in main board and take the opportunity to resolder all the griplets. Hopefully no more random fails anymore ever then.
Now that it's ressurected, and another laser saved from erroneously being diagnosed as dead, I'm really motivated to do some simple and inexpensive mods (dedicated 5V for SA7220, cleaner supply for DAC, new opamp for output stage and audio grade caps in audio path) and then in the end sell it, as I already have a nice TDA1541 based player at home.
When all is done, I'll post more photos also of the rest of the player and final results. In the meantime, would be interesting to hear opinions about these random fails it had and which magically seem to have gone...
Also any additional suggestions of simple and inexpensive mods are welcome, thanks!
Attached photos show that plastic thing which had fallen off marked with red arrow and also sticker saying cdm4. Btw, the metal plate of the spindle motor where the CD sits on, has some kind of "residue" at its edges (is dark grey, almost black, easy to see in picture), is this "dirt" and should I scrap it off carefully or is this some kind of layer to better grip the CD which has deteriorated so I really shouldn't touch it at all??
Ok, I've got it finished - it's working perfectly, very quick access to TOC and track change, never skips, even CD-Rs and badly scratched. And is sounding very nice. Ready to find a new caring owner 🙂
I changed all electrolytic caps, taking care to use audio grade caps in audio path, changed opamps (installed sockets) to LM4562, installed dedicated voltage regs for 7220 and tda1541 and installed a few bypassing caps in critical places (opamps, parallel to output caps). It's a really nice little player. If it wasn't for all the plastic parts and if I didn't have a slightly better Marantz which I hevaily modded (installed a new clock), I'd keep it. But like this, I'm going to sell. Attached some photos.
Hi, I just got the same cd player from ebay. It wasn't reading most cd's so I changed the blue 33uf cap in the laser power supply and now recognizes all the cd's! As a precaution i would like to check and readjust the laser voltage if necessary. But i'm not sure where to measure it. Could you let le know where you measured that voltage? I'm guessing the trim pot not far from that blue cap is the one used to then adjust the voltage.
thanks for your help.
ben
Ben, that's great to hear, I think that infamous cap is one of the most common causes people are wrongly led into thinking a laser has died, when in fact it's only the cap. Fortunately it starts finally to be a well known repair.
Yes, normally the POT for laser current is close to that cap, on most CDM-2 boards (there are several versions!) there's only one POT, which is the laser adjustment, but some have two (the other is focus offset), there you have to be more careful when adjusting. If it's a pure CDM2 it will be of 1K, if it's a CDM-2 which has received the CDM-4 laser upgrade, it will have been changed to 4,7K. Focus offset, in case it has two POTs, I think is 22K.
The POT is also fairly close to the BC338 transistor which drives the laser.
Please don't forget that you don't measure the adjustment at the POT, it's at test points 1 and 2 (across resistor 3102, as far as I can see here in manual)! If you don't have the service manual of CDM-2, I can send it to you if you PM me your e-mail address.
Also be very careful turning that POT as a little too much can kill the laser (it's really sensitive), also remember voltage will get higher towards the end of a disc or with CD-Rs, so try to adjust to 50mV when playing somewhere in the middle of a pressed CD.
ben
Marantz CD273 NO Power...also.
Hello. The front panel on/off button (203) with a broken tang doesn't move the long rod (216) that pushes the on/off switch (226) with a blue plunger. I manually plunged the plunger on the switch but the unit doesn't power up. I have not checked the ON/OFF switch for operation. I assume it supplies the (227) voltage selector switch. Can the VSS be cleaned with a spray deoxidizer like Caig Deoxit? This was a Netherlands based unit. It is possible the VSS has never been turned from the EU settings in 30+ yrs. I tried both 110v and 127v settings on the VSS. I doubt I'm capable of bypassing the VSS to go direct into the tranny. Additionally, I can't find the tranny fuse. What color/where is the screening cap? I did swap the mains fuse to the 400 mA rating for 110-127v. This is my 1st attempt at this sort of endeavor. I could use some help. Thank You, civil6.
What I find interesting in your strange CD 273 is that it has the later board with the TDA1541A.
Most of the ones I have seen have just the plain old TDA1541 .. not A.
Some even have a strange DAC chip, TDA1541S yes a selected chip which the purists state did not exist yet I have 3 examples.
Andy
Reactions: Ivo-Cici
You seem to have two problems here... one is a broken mechanical component which is necessary for the on/off switch to work. You will have to fix that somehow or otherwise install a switch in the front panel, which is not an elegant solution - changes the design and also you're taking hazardous mains potential to the front, so avoid. Better build your own tang or adapt from somewhere else.
You could test the mains switch, but I guess it's working, if seller says the player was working fine with 220V. Also these mains switches are not prone to failure.
It definitely seems to be voltage selector. Have you tried cleaning with deoxit and changing position several times?
I had a look into the service manual, unfortunately the wiring that is shown (and which helped me a lot in my situation) is for 220V setting. I guess there are only two ways to find out the correct wiring to hardwire the VSS:
1. compare with a working player of this kind where voltage selector is set to 110V (measure connections with multimeter for continuity so to find out to which transformer inputs the mains go to)
2. measure all transformer inputs for resistance so to find out windings and then apply logic... the windings for 110/120 are going to have less resistance than the 240V taps, and often there are two identical windings which will be connected in parallel for 110/120 or series for 220/240V.
There's not much more you can do. If that's beyond your capabilities, maybe you should hand it over to a technician. Playing around with transformer primaries can be bad, altough you're in the less dangerous situation: 110V will not ruin the transformer if connected to 240V winding, but the other way round could be bad.
You can always use the light bulb trick or even a variac if you can get your hands on one. Then you could find out the right winding with less risk.
Andy
Yes, definitely there are some odd variations on some of the Marantz/Philips players...
Actually wait.. I overlooked something in SM... in the schematic, numbers are given for the connections of transformer primaries... numbers which then appear in the drawing on other page where connection to voltage selector and transformer is shown. Actually it seems easy for 110V... it does have the two identical windings, they are connected series at 10 and 12 for 220/220V. So, simply a matter of not conencting 10 and 12, instead: one mains line feeds 1 and 10, the other 12 and 5.
