Hello.
I have bought a Willsenton R8 amplifier.
I will use Genalex Gold Lion KT88 reissue power tubes and I'd like to know what kind of 6SN7 (x3) + 6SL7 (x2) shuold you reccomend me not expending more money in tubes than in the amp itself.
I have RCA 6SN7GTB that I could use... what 6SL7 for those?
Attached you will find schematic if it helps
thank you.
thank you.
Personally, I prefer Soviet 6N8S and 6N9S. Others may not agree, but I like them and they are affordable.
are those from your suggestion direct replaces for the original ones?
Yes.
6SN7=6N8S
6SL7=6N9S
I was looking for my next amplifier project , and found this thing.
Are these any popular ? Any interest in a variable Triode mode to Ultra linear mode ?
Connect Willsenton R8 to a sub
Did anyone connect the R8 to a sub?
I used to connect my solid-state amp to the sub with a jumper from my loudspeakers to the high-level input of the sub. I wonder if I can do the same to the R8. any insights would be helpful. thanks.
I use a REL sub with my Willsenton R8 and highly recommend it. Connect the REL to the 8 ohm taps on the R8, even if you use the 4 ohm taps for your speakers.
You have my curiosity up. What “thing” did you find? Must know what “thing” is before we could assess if it is popular or not.
@Francois G, I think he was referring to the amplifier subject of this thread. This brand seems to be popular at least judging on youtube videos...
@realman, I would leave it as is. RCAs are fine anyway.
- Tubes / Valves
- 6SN7 + 6SL7 suggested combination for Willsenton R8
