in search of a schematic for the original ASL AQ-1006 845 amplifier
New Page 1
Do you find power transformer part # here? The original website is not accessible or updated, these infoes could be the last archives I think.
I do find a 845 but not AQ1006 with AC heater supply here, just do without DC rectifier.
I think these are early amps and there was a lot of changes on the later ones. The ones I'm working on use a voltage doubler for the high voltage and all the filament/heater supplies are AC. I have everything working now. It just would have been nice to have the proper schematic but I have it figured out. Thanks again.
all the ASL 1006 that i repaired, about 5 of them had dc filament heating, an mda3500 and huge cap....
strange, but these versions had the cathode followers made into cascaded cathode followers just so they can add a coupling cap, crazy thing.....so what i did was to restore it to original schematic..
Feel free to drop your reverse engineered schematic here, could be useful for someone in your position years from now
The audio circuit seems to be the same as the schematic in post #2.
The 845 B+ is a doubler and the raw B+ for the regulator is tapped off of the doubler and the bias voltage is half wave. All the heaters/filament are AC.
I think that says it all.
