Bose: Small enclosure, long port, how?
That isn't a subwoofer for starters it's a bass module, it has to cover everything up to about 250hz to meet the cubes. And Bose isn't afraid of applying heavy EQ to make cheap parts do what they want. These things don't work half bad for the $50 in components they contain... LOL!
attachment.php
It's a 1/4 WL pipe harmonic: ~13543"sec/4/30" = ~113 Hz
GM
The first mode of a pipe with two open ends occurs at 1/2 wavelength, so for a 30" or 76 cm port it occurs at 225 Hz.
This is a modified port, where porous aluminium sheets are placed to reduce the resonance.
+1, The grey windows are located at approx. 1/2 and 1/4 port length, which coincides with pressure maxima of the lowest (in frequency) modes of the air column within the port. Therefore they seem to be added to introduce damping to the first modes. I have read about drilling holes in a port to the reduce port resonance years ago, but never seen it been used until now. 🙂
Thought the port length might be right, the resonances are difference due to that.
I do not think they will alter the resonance frequencies that much, because the windows have a small area, compared to those of the port ends. In addition, they are covered by flow resistive material.
An 11" cube enclosure, and an overly long port of about 30" with port resonance at about 113Hz.
If the long port was a tuned 1/4 wave pipe (TQWP), it would resonate at ~113Hz, not useful as a subwoofer.
Appears to be a parallel sixth order band pass (BP6) enclosure, each of two chambers with their own ports.
With such a small cabinet volume, a low ( ~40Hz?) tuning with a large cross sectional area requires a very long port.
The long curved port exits at the bottom to one side of the amplifier compartment:
The upper port(s) exit through the upper slots:
The upper chamber is rather small, a good portion of it's volume is the woofer cone's concavity.
Art
Reactions: stv
