Hey guys,
I'm building some amps and am looking for good quality panel mount fuse holders.
Does anyone have any experience with a certain brand or type?
thanks
Sam
thanks
Sam
I use 1/4"x1 1/4" fuses (AG3 in fast blow) for long term availability, also stocked at local auto supply without a freight bill.
The littlefuse & buss panel fuse holders from distributors are fine. They fit in a D shaped hole, so I drill undersized then finish out the hole with a rat tail file. A real file from nicholson, not some import toy.
Where taking the cover off is not a **** , fuse clips that mount inside are easier to machine, requiring 1 or 2 holes to be drilled for #6 screws. My projects are checked out on a light bulb box and don't often blow fuses.
As I know there isn't such a strong dependance between a rated current and a fuse size. Fuse size more dependent on maximum breaking capacity or reliability (under large currents/voltages).under 4A = 5x20 or above 4A = 5x32
@Vovk Z: You are right saying Fuse size is dependent on maximum breaking capacity or reliability. It's more a pratical design rule based on general holder capacity and under sizing for security (intensity vs contact size, fire...).
By the way, I also prefer a slow blow fuse before a transformer.
Correct. 5x20 (mm) are the ones distributed in the metric market, 1/4" x 1 1/4" are for the US market, also for some Europeran automotive. I have 5x20's in 10 A slow blow, for instance.As I know there isn't such a strong dependance between a rated current and a fuse size. Fuse size more dependent on maximum breaking capacity or reliability (under large currents/voltages).
Best regards!
Dimensions of a 1/4x1-1/4 and a 22LR differ in so many ways nobody could take it seriously.
And the story is far older than the innernet. I heard it in the 1960s and it was old then.
Hey guys,
thanks
Sam
you need to add your location to your profile so we can help better.
RS Components or Farnell sell a good range of good quality.
Does anyone know if this is a good product?
BK/HKP-R Cooper Bussmann - Fuse Holders - Distributors, Price Comparison, and Datasheets | Octopart component search
I use these in all my amps. They work fine.
Mount Screw Fuse Holders 250V 10Pcs Set 5x20mm Panel Case High quality | eBay
Schurter "FEZ 755M/756" - other Brands in this Outline ?
Who offer fuse holders in the same outline than the showed Schurter custom made version (i. e. with screw terminals instead solder lugs - have a look to the attached image) ?
The versions under
https://www.amazon.com/Parts-Express-Terminal-Holder-5-Pack/dp/B072YLL65L
and
Fuse Holder with Fuse Clips 6 x 30 with Screw Terminals Brand Feme : Amazon.de: DIY & Tools
not helpful, because no panel mount version.
The versions under
and
- Design & Build
- Parts
- Panel mount fuse holders.
