Hello,
I`m modifying a relay with DC coil to be triggered with AC.
I want to keep everything in the relay itself, so size does matter.
I added a diode (half wave rectifier) and a 200uF capacitor.
Relay works, but I have 11v ripple 😱 at 12v.
Is this bad for coil? I will need around 2200uF capacitor to smooth this out, but in that case I will have to fit it outside the relay.
So will ripple damage the coil? If yes, how much ripple would be acceptable at 12v?
Thank you
Thank you
Can you use a full wave rectifier? That would reduce the size of the capacitor needed.
The relay coil requires a certain minimum voltage, which constrains the ripple.
That was the original plan, but when I opened the relay, I realised that I can unsolder only one coils wire from the terminal, the other one is unreachable.Can you use a full wave rectifier? That would reduce size of the capacitor needed.
The relay requires a certain minimum voltage, which constrains the ripple.
Hello, no it doesn`t, it stays closed.Does the relay rattle when activated? If not, I don't see any issue.
Best regards!
I was just wondering if it will damage the coil.
If it wont do any damage, then problem is solved.
It won´t damage the coil because it´s highly inductive and tends to keep current constant, but I am amazed at the huge 11V ripple on a 12V supply.
Coil inductance will integrate that so it´s as if you had around 7V DC applied to it.
I don´t consider that reliable operation.
You were asked if it chatters, for good reason.
Can´t you generate "good" 12V outside, at some convenient place (even quite a few inches away), with a bridge and a larger capacitor, and feed resulting dc to relay through a couple wires? No big deal.
- General Interest
- Everything Else
- Is ripple bad for DC relay coil?
