Bi amping - JLH 1969 for scanspeak d2905
Thanks guys.. Not that tech savvy though ;-)
This is the version I have (supposedly 2x18W, though I think thats a bit exaggerated):
Hood 1969
I have already bought 2200uF Mundorf capacitors to replace the current 1500 uF (supposedly bad quality) ones.
Not sure which ones are the ones you are suggesting to replace t 10uF/10n now? 🙂
The JLH 1969 circuit is 10W the 1996 circuit is 15W --if you read my post #3 link.
If they are saying its 18W then it isn't the 1969 circuit --OR they have modified it by using much higher gain output BJT,s which looks likely going by your pictures .
I ran the JLH for tweeters too at first, but I think where it really shines is in the midrange, so if you have 3-way speakers, run mid&tweeter on the JLH.
If you want to improve bass, increase C1, C3, C4 and C6 x10. Maybe after this you could use it full range.
