Global Feedback - A huge benefit for audio
For $16500 a pair I'd rather have 30dB better performance. That's a LOT of IM products with only 2 tones. I'd let a $1000 amp get by at that level, but fail to see what I am paying so much for.
Any sane person would agree to this. It would be real interesting to search for amps with comparable or even better performance. How cheap could you go?
PS: You're clearly paying for the sexiness. See the first paragraph of the review.
Quotes for laughs: "Maybe it's just me but I've never found any piece of electronic equipment sexy."
"Sexy? God help me, I do think so."
"I have some beliefs that approach religious faith: [...] zero feedback is better than feedback"
And if you just said amen then you're a true believer. To join their church you just need to sign this check..
Audio is about reproducing music for a human listener.
The human is the ultimate judge. There is no escaping this.
Denial is futile.😎
Denial is futile.😎
Did you read my post #1895?
It doesn't matter what you prefer. You may prefer these FX amplifiers with expansion and compression effects, coloring distortion, fixed EQ-like interactions with your speaker's impedance, and so on.
But technically, this has nothing to do with accurate, high-fidelity amplification.
You are excusing your inability to solve a difficult engineering problem by claiming any listener of the audio product is incompetent and, instead, you choose an electrical measure whose relevance you have not proven. Daft, I call it.
Even though a ridiculous statement, at least you admit it's an engineering problem!
For a moment there I thought that you think this is an art problem.
Since you seem to know better, which electrical measures other than noise, linear and nonlinear distortions do you suggest to measure electrical amplification fidelity (which literally can be defined through lack of noise, linear and nonlinear distortion)?
.. and the fallacious argumentation continues. Throwing the baby out with the bathwater.
You clearly belong to what I described. Only ideological black/white thinking.
There are several issues with these statements as well.
First, there are people that are technically interested, that want to understand the circuits, different techniques employed. People, that want to push what is possible even if there's no obvious practical benefit. Limits regarding weight, size, cost, simplicity, linearity, and so on.
Is there some audible benefit to adding another "0" to already vanishing low distortion numbers? No, but it's still an achievement. Technical superiority. A challenge, that some enjoy to tackle.
This is also what drives technological progress.
Sadly, there are also the ideologically driven simpletons that demonize things like global negative feedback. To them, the hobby seems to be congratulating each other on the next more expensive purchase which obviously is an upgrade, duh (even if the amps are so nonlinear that they cause audible effects). Confirmation bias echo chambers.
Secondly, it's again not as simple as "low distortion can be achieved without global NFB". As others have pointed out, for powerful amps (and not mW headphone amps) the distortion actually isn't always that low, and the output impedance still can be high enough to cause an EQ effect.
And some people prefer having a fixed high output impedance that causes an EQ effect, or distortion so high that it audibly colors the sound. Which is totally fine! But that is a matter of personal taste (or lack thereof), not of technical facts.
And I think this is where (a part of) audiophilia has gone completely wrong. Because these people failed to correlate technical facts with subjective, biased experiences, they raise their experiences onto a level that allows them to - seemingly objectively, but this is just an illusion - discriminate between tastes .. and look down on others with "lesser" tastes.
Technical facts are irrelevant for them. They're merely ideological tools.
One would think that this is absurd and could not be true, but the industry has actually adjusted to this and makes good money off of them.
A synopsis of your long post is that some get carried away by the process and forget the original purpose. Vanishingly low measured distortion becomes obsession. But there is no objective evidence for good measurements correlating with good sound. Their is faith, nothing more. You ridicule subjectivists for their faith, without noticing that you are as ridiculous with your objectivist faith.
