Hello guys,
I have two tansformers with the following parameters:
- 2x27V secondary voltages
- 150 - 200VA
Which amplifier should I build for these? My preferences are:
- I want a good quality amp.
- Should be easy to build
I have found this Hiraga amp.
Do you have better advices? Are there better amps to build?
- 150 - 200VA
Usually they buy a transformer after choosing an amplifier circuit)))
You can get bipolar voltage + -35 V at current up to 2A.
To build any amplifier is (equally) difficult. You need to have different skills and the right hands. The cost may be more than a good used amplifier.
Online shopping will help you. You can buy ready-made cases, sets of parts, PCB.
It can be expensive or long (
Do and have fun with DIY.
Some of my design was compared by local audio community with several branded amplifier which more expensive about 2x ~ 3x. They said, my amplifier is better. Of course, development cost is high, but built unit is much cheaper.
Hello guys,
- 150 - 200VA
Do what gives you the satisfaction of building. The Hirgara looks nice for your application. Just be aware that a 30 watt class-A will need to be built like a 150-200 watter (heatsinks, capacitance, chassis size, weight etc).
Good luck. I am sure it will sound sweet.
- Poweramp advices
