Ok i removed the diode very carefully and no i have a number:
C106A2
2 one at each end just like a diode
C106A2
Is C106 printed on the device, or are you reading that off the PCB silkscreen?
Europa
This is a 6 amp diode with about 50 amp surge
This guy from Aussie does not have knowledge of car amps.
Who uses an SCR as the reverse polarity diode?
Does anyone know who may have schematics of a Hifonics Europa VIII? I just need to know what diode to buy/use.
C106 is printed on the amp board and the diode itself has either 16 6 A 2 or 10 6 A 2 markings. Any help will be greatly appreciated.
Ok from doing some research I have notice that Hifonics used the 6A2 diode on the majority of the amps. Looking through the amp guts the 6A2 diode is found everywhere.
H - AMP Performance
Come on someone should know the correct diode to use.
H - AMP Performance
Buy a 6A2 diode available from many suppliers.
SCRs have 3 legs!
Thank you I will look for one
- Design & Build
- Parts
- Hifonics Europa VIII Schematics
