D302 (Ge) diodes
I would guess it is for voltage balancing given the high leakage of Ge devices. Ultimately it will depend on the max voltage you apply to the series connected diodes. If the total reverse voltage is approaching the sum of all the individual diodes Vr then you would need the lower resistance values to ensure forced balancing of the volt drops.
That's my best guess 🙂
Thank you for your answers 🙂
It's for a 300Vac PT, 8 diodes for the bridge (twice, in series), it works but 15K on each diode is 60K for 4 diodes but the result is 30K, too much power waisted.
So I have to try 30K on each diode then measure the resistor current to be sure it's much higher than the D302 reverse current at 25°, right?
Or build a bridge with 16 diodes, nice looking 😉
of course, Si diodes are the logical way.
But I wanted this time to do a different looking amplifier, ok I'll go with 16 x D302 B+ bridge rectifier. And D303 bridge for positive bias of the 805 grids.
Didn't measured yet voltage across D302 bridge, maybe 20K on each diode will do it, they won't be stressed at all.
Finished yesterday manual winding for the two 805 heaters (made from a 0.68mH mundorf aircore inductor for speaker crossover).
Recycled wood... in the woods near a river and copper from an old heating setup.
Takes a lot of time to paint everything with a small pencil 🙂
Thanks all 😉
I think it may have a secret compartment containing a tray of spare ge diodes.
Very good idea.
Nothing really special, cheap metal oxide 5W resistors, Solen SCR caps for positive grid fixed bias, Wima DC-LINK PS caps, Hammond 3.5H 150mA choke.
PT & OPT are from a Quicksilver amplifier.
I may cover the toroids but first be sure they don't heat too much, it should be fine (160VA core).
These monoblocs will be driven by another smaller amplifier.
Hope it will work fine.
Yes, it took a lot of time for the painting job, and that's not finished 😱
