ground Zero, gzua 1.1000
ground zero 1000
Hei, pin 9 and 10 on psu driver board goes to sense resistors.
i just have this piece from schematic, which is similar to the one I have. ...
on pin 9 and 10, has a resistor going from each rail to the psu driver board.
i just wonder if i has something with regulation or just checking the rail.
I believe it was some 1.6volt plus minus on pin 9 and 10
Is that part of the diagram all you have or simply all you're you're willing to post?
The amps using this output type are typically not regulated. Amps with regulated rails typically seen the feedback to one of the error-amps on the driver IC, not to terminals 9 and 10.
Hi Perry, what the owner of the thread meant is that on pins 9 and 10 of the driver board there are 2 resistors (on the side of the amplifier board) that go to the rails, in the schematic, pins 9 and 10, are respectively - / + rail sense and I can guarantee that they are used to make the regulation.
In the past I have repaired an amplifier that had the same driver board in the power supply and also had the 2 small resistors on the "+/- rail sense" that went respectively to + and - rail of the amplifier and that was regulated.
Also, if you notice well, +/- rail sense, they go to one of the two error amplifiers, so it makes sense.
OK.
So what's the regulated voltage?
Where is it supposed to stop as the B+ is increased?
Can you post the rest of the diagram?
This can only tell you by trean27, but usually I imagine that if its rail caps are 63 volts, the rail voltage must be around +/- 58v with battery voltage at the maximum allowed and keep roughly that voltage both if the battery voltage drops, both if the rail itself goes down.
Am I wrong?
It could also be different:
Logically, if the regulation is used to keep the rail as stable as possible, in the absence of load and with the regulation circuit not working, perhaps the rail should go even beyond the value of the rail caps.
Maybe you can but I can't help without knowing more. I can make assumptions but that can provide no definitive answers. If the OP isn't willing to post the diagram and no one else will, I can do no more. The overall amp seems to be common but the regulation in this type of amp is new to me.
Thanks for correcting me on the pin confusion. I misread and thought he was referring to the IC. I wish he would have corrected me earlier.
I've sent to you an email! 😉
What are the regulator resistors in your amp. The diagram that I received won't be the same. They are R183/184 in the diagram I received. What is their value in your amp (not in the diagram you have, the actual resistors in the board)?
