Active discrete Baxandall Tone Control
Based on famous principle of Tone Control by legendary audio engineer Peter Baxandall , After messing around in breadboard , I successfully designed a decent Tone control for Single Supply use for TPA3118 , TDA7297, TDA7376 . Now many people will Why go discrete when opamps are available . Well NE5532 on rail splitter did so up some noise on my CRO.
It uses very easily available components
I want to see how it performs on KSC1845 but for now i have used BC549B for buffer stage and BC549C for Tone Stage.
https://i.ibb.co/NjhPBRr/IMG-20200627-214541.jpg
Please have a look and any recommendation/criticism is always welcome to me.
Hope I spent my LockDown well on a fun little project
Pots are 100k each , Lower is treble whereas upper one is bass.
Edit: I fixed Typo and Schematic , Updated information about pots
Have a play with this if you want to practice simulating. R18 and R19 and R21 and R22 are the two 22k pots. So it is in the flat position here.
This circuit is very old and from Wireless World in the late 70's as I recall. It will give you something to compare to.
  • Discrete Tone Control.asc
This one from Mooly looks better, with one transistor emitter follower as buffer, and two transistors for Baxandall.
But i still think that it will clip at 12V.
Well i do not claim my design better than anything , I made what ever i could on a bread board , two 9V battery , spares lying around . I didnt clip on 18V supply though. Mad mans design not for serious use.😛
Thanks for help as_audio , nironiro and Mooly
