100 -200 watts @ 3-8ohms for Alon IV
Hi guys ,can you help make recommendation on a budget-friendly 100W-200W home hi-fi amp which is happy driving 3 Ohms.
I need one to drive a pair of Alon IV. I don't mind a DIY or any off shelf solution as long as it's works.
For what you want and the loudspeaker company advises 200W not 100W I would suggest a mosfet power amp they are pretty un-burstable
at low impedance's.
It must have a very powerful power supply, weedy ones will not do but you mention--"budget friendly " that's not easy unless you DIY .
The speakers you have cost a lot and looking at the design & crossover which is non standard normal small power amps are not for you - big-beefy with big heat-sinks unless you buy other than class A /AB1.
Looks like the specs of the Parasound would suite the bill.
200W into 4 ohms is good .
45amps peak says the power supply will cope BUT do NOT run it at FULL output as 2 ohms will damage the amp and 3 ohm speakers can hit that in places .
The manufacturer warns about this ---do NOT use in bridged mode --only ONE pair of speakers allowed to be connected .
Heed those warning and it will work --ignore them and I take no responsibility for any "burnout .
For the amount of power you want 200W out of the two you have provided Passlabs X250 fits the bill , Honey Badger is 150W.
A demo model in Reno Hi-Fi is selling for $7000 , this is anything but "budget friendly " though.
Reliable big power amps cost in hardware you could build but it still wont be cheap for the parts including a massive mains transformer .
Kindly explain,do you mean the Bose is not recommended. Or settings below 4 ohms are not recommended
In the PDF of the specifications it is not recommended for use below 4 ohms .
When a manufacturer specifies a range of output impedance,s
of an amplifier it is for the safety and long term well being of that piece of equipment.
In this case the wattage increases significantly at a lowering of the impedance ,in many cases this is a good thing but at 3 ohms the current drawn would cause problems in the power supply and output .
If you look at a graph of a 3 ohm loudspeaker you will find it even dives down to 2 ohms at certain frequencies at that impedance if sustained can certainly cause a design that increases in drawn current at lower impedance's that isn't designed for it to fail.
Many power amps are limited that amp isn't .
You can buy it ,its your choice but if you plan to use the full
wattage then,as I said problems will arise .
You can completely ignore my post its a free country but I am going by the manufacturers recommendations .
Understanding Impedance Curves & Phase Angles | Audioholics
