Electrolytic Capacitors Running Hot Help
Please see attached part of the schematic. This is a delayed turn on and protection circuit for an SS power amp. There are two electrolytic capacitors, 220uF and 470uF. Before repair, the 220uF cap was completely dead, showed 0uF and many parts such as surface mount resistors were all burned out around it. I replaced the bad parts, the amp now turns on and off properly and performs as expected.
But these two electrolytic capacitors get very hot. Too hot to the touch. Beyond 60 degrees Celsius. I’m assuming this heat is what caused the original cap (cheap 85 degree Lelon) to fail and take out the circuit. The new caps I put in are 105 degree Panasonic FR.
Any idea of why these caps are running so hot by looking at the section of this schematic? Any help or advice is appreciated.
Your circuit as shown has the VCC supply at +70VDC and the caps in question are only rated at 16VDC as per the schematic.
What is the actual voltage on the 2 caps - what ever it is, add 20% safety factor to get the properly rated DC voltage for the caps.
For example if it was 50VDC, then use 63V rated electro caps - definitely not less than the actual voltage as measured with a DMM.
No wonder they are running hot and have failed to an OC.
Caps have 4.5mV AC on them. Polarity is golden. Main power supply is dirt simple toroid, NXP Schottky diode discrete bridge, and 3300uF cap. There are also two LM317T regulators which feed the chips.
Would be useful to see more of the schematic to see what is going on.
Are the connectors TP24 to TP27 and TP28 to TP31 connected somewhere else in the amp?
Must be something driving power into the capacitor if the capacitor itself is heating up and not being heated by parts close to it. It is just connected to an op-amp input according to the small part of the schematic you have shown (i.e. serves no purpose?).
Unless there is another fault like the divider (R15,R16,R17 etc) on the 70V input to the opamp has failed, the opamp won't survive 70V on the inputs, who knows what failure that would cause.
