Need help on Kenwood repair
My KA-5002 is not working. I may have narrowed it down to the amp board when I experienced no issues using an amp board from a working donor. There is a short somewhere I cannot narrow it down further. Test points are good until the protection circuit and B-.
Drivers are new KSA1220AY/KSC2690AY pair. Diff inputs are also new, and I can center those with Vr1,2 fine according to service manual.
B- drops to -24v on a 40w dim bulb. If I pull the output transistors it gets proper -35v on dim bulb, bulb is dark, relay clicks. With outputs in, the bulb is really dim, then brightens up a little after 2 seconds, no relay engagement.
I checked resistance of the output emitter resistors they all are good. I did diode test on the output transistors twice, check out good. Unit works with donor board, relay clicks in fine.
I did find and replace a bad De6 flyback diode.
When powering on with dim bulb, Qe18 collector briefly surges to 30V, then drops to 3v. Qe17 emitter reads 3v on dim bulb.
I need help from the pros! I would appreciate your investigative skills. I put red dots on test points that read bad. Pins 6 and 14 go to relay, it got cut off.
Kind regards.
attachment.php
I took same readings from working unit
Qe13 E= 78mV C = 48V, B = -62mV
Qe14 E = 69mV, C= 48V, B = 2mV
Qe15 E= 30mV, C= 48V, B= 20mV
Qe16 E= 48V, C= 5mV, B=48V
Readings from not working unit
Qe13 E= -10mV C = 39V, B = -10mV
Qe14 E = -25mV, C= 35V, B = -17mV
Qe15 E= -6mV, C= 36V, B= -8mV
Qe16 E= 39V, C= -200mV, B=35V
There is approx. 9v-12v discrepancy for all the above off readings, 10v discrepancy for B-
One anomaly I found on both amp boards, 100uf is installed instead of 220uf for Ce18 position as shown on schematic.
Since De6 was previously shorted, I pulled and tested Ce17 33uf, which tested good. I replaced it anyways. Schematic shows 47uf in that position although 33uf is also in the working board.😕
Boy this one is getting the best of me. I reattached the collector wires to outputs. Found I made bad choice for De1 DZ-140 sub had in 1n4148, replaced with 1N5244B.
Although they tested fine I replaced the last two semis i hadnt swapped out Qe7,8 bias transistors with ZTX696B. Unit came out of protection, B+ still sagging like an old ladies tits by 12v, bulb lightly dimmed. Turned on/off few times, wont come out of protection again. Turned bias pots all the way to nearly 0. Came out of protection again.
Pondering tracing a signal to see where it becomes a problem but unsure if the -12V sag will defeat that effort.
Q1 E=.67V C=-22V B=.56V
Q2 E=.65V C=-21V B=.53V
Q3 E=.77V C=-23V B=.13V
Q4 E=.76V C=-23V B=.13V
Q5,Q6 DONT EXIST
Q7 E=-21V C=-.9V B=-22V
Q8 E=-23V C=-1.3V B=-23V
Q9 E=.35V C=24V B=.9V
Q10 E=.74V C=23.9V B=1.3V
Q11 E=-.38V C=-23V B=-9V
Q12 E=-1.3V C=-23V B=-1.3
Kind regards.
Appreciate the assistance. I remeasured Tr4 today and got a different reading
E=.4mV C=-23v B=-.350mV
When amp is turned on, before relay engage, E=40mV... then drops to .4mV after engaged.
Tr4 does not seem to be opening although it passed a diode test. I may experiment with On Semi replacements MJ21193/MJ21194 for Tr2,Tr4 unless advised otherwise.
TR1 E=85mV C=23V B=.74V
TR3 E=115mV C=-23V B=-.76
TR2 E=-15mV C=23V B= .32V
TR4 E=.4mV C= .4mV B=.4mV
correction on Q11 B=-.9v
Bad Tr2,Tr4?
Replaced Tr2,Tr2 and she finally came out of protection and dim bulb was dark.
Now I read 87mV on both of those emitters instead of 4-15mV
Looks as though the 6 point diode test results are not 100% definite :irked:.
Only took 6 years to sort this one out! 😀
