different audio forum
jj,
I have a set of Burhoe acoustics 'blues (10" 3-way)
the burhoes,genesis, epi (maybe others?)speakers by Winslow Burhoe of that period 70's-80's had woofers left to roll off on their own, straightwired no xo, just a cap and pad on the upper registers.
anyhow point is, the blue with the original woofer in place was one of the most dynamic sounding bottom ends I've ever heard, so it might not be the issue.
Can you supply links to the woofer and kit so I/we don't have to do the footwork?
Here's what I garner about hysteresis from the web. I don't know of a link between it and inductance. Hysteresis results in magnetic materials causing non-linear distortions due to differences in the paths followed during magnetisation and demagnetisation.
Hysterisis
When using an iron based magnet in loudspeakers, it is not unusual to experience a phenomenon called hysteresis, which is a well-known problem in almost all speaker magnet systems. The magnetization and demagnetization, which happens by the shifting current directions, does not happen at the same time as the demagnetization process is slower than the magnetization process. It occurs because iron is not only magnetically conductive but also very electrically conductive.
The problem with hysteresis is that it introduces an unintended resistance to the voice coil, meaning unwanted distortion. This is dramatically minimized when using the very highly magnetically conductive materials.
" .... Can you supply links to the woofer and kit so I/we don't have to do the footwork?..."
Sure. SEAS A26 Kit and SEAS The Art Of Sound Perfection
This comment from an audiogon discussion:
" ... 09-02-2019 5:09pm
Many of these minimal crossover speakers use mid/woofers with an abnormally high voice coil inductance .The SEAS A26 are an example of that.So to claim there is no crossover on the mid/woofer is arguably misleading.It is just that a first order crossover is built into the voice coil .The mid/woofer in the A26 kit for example [the 26RE4] has an inductance of 3.8mH.Most similar drivers have an inductance of more like 1mH....."
So maybe there is no relationship between hysteresis and inductance, eh? From what I could gather, the relationship (if there is one) would only show up when the speaker had been driven for quite a while, or had been driven hard.
Like I said ..... I don't know. I'm in the dark. jj
jj,
I never heard Burhoe (or EPI) speakers. I wish I had. Burhoe had quite the reputation, and from what I gather, quite deservedly so. jj
Here in the UK,I've never even heard OF Burhoe (or EPI) speakers!
And I am more familiar with hysteresis in tyres, particularly motorbike tyres.
I found this site. You may wish to peruse it. From what I understand, this man (Huw Powell) had Burhoe as a mentor, and has taken a direction with his own business that resembles Burhoe's to quite a degree. Notice one thing, however: nowhere on this site could I find any response charts. Alarm bell, right there. jj
Not sure if this is relevant as it’s above my pay grade also.
(PDF) Experimental characterization, modeling and compensation of rate-independent hysteresis of voice coil motors
Yeah, an old fart like me views this as gobbledygook that's impossible to understand. I did notice one thing, though: the inductance of the VCM that they were measuring was only .5mH. I wonder whether a VCM with much higher inductance would have shown not only different results but the emergence of different problems. jj
