Good evening, I am a new member from Italy, my name is Emiliano, I wanted to make an Aleph 5 finale but I have problems finding mosfets, can you give me equivalents and articles where we talk about this realization?
Thanks in advance.
Thanks in advance.
IRFP240 are easy to find, but you need matched ones
one matched group for upper half, second matched group for lower half
plenty of Aleph threads, not necessary to focus on Aleph 5
read, think, then build
Good evening, I wanted advice on heatsinks, I found this case complete with heatsinks, could it be fine or is it under-sized?
Dissipante 05/400N 5U 4mm NERO
Ciao,
I think you must use 500 mm 5 U
dissipation is slightly above 100W per channel
that calls for 5U/500 Modushop case, for stereo amp
- ALEPH 5
