Wharfedale Linton MK2 - degraded on one channel
I am getting loss of volume and distorted sound on the left channel.
Looking at the circuit board the tinning has disappeared on part of the board, image attached.
Is this a problem or am I more likely looking at capacitor failure?
Any advice gratefully appreciated.
It might be corrosion damage - have you checked the continuity of the trace around the area where the solder's vanished? It looks like there are some areas of dull brown etched copper. It might be failure of wave-soldering during manufacturer as mentioned above, but I hope that would be rejected by quality control.
The actual fault is more likely to be something else I suspect, dry joint, capacitor or similar.
Thanks for the link Ian. Unfortunately I can't download the manual without registering on the site and the registration page is broken. Would you be able to attach a copy?
Thanks Galu, I have printed a copy and will now lock myself away with a magnifying glass and the circuit board.
@ Red Crab
I've discovered that, although the Linton amp (1971) was of Leak manufacture, the Linton Mk II amp (1972) was of Japanese manufacture.
That being the case, the circuit diagram for the Mk II will prove impossible to find. 🙁
Component identification
Ok so it's going to be trial and error then 🙂
Luckily I have two Linton MK2s, one to test dismantle which has no stereo channels at all, and the other which is fully working just distorted which is my first target to repair. The ultimate goal will be to have both working.
Can anyone identify this component from the mono only amp which has been worked on by someone before and been removed (images attached)?
IF they have connecting copper on the reverse of the PCB then they represent a full wave rectifier in unusual block plastic shape .
If NOT then they have another use --notice the AC symbols on the second photo.
The first photo looks like capacitors but could be something else .
60,s/70,s capacitors were usually encased in rectangular block plastic ( non-electrolytic ) they came in a wide dyed range of colors.
I can tell you when working properly it was a very good amplifier. In about 1971 it sold for £40 and the Leak £49 at discount prices. The Linton was nicer looking. By comparison the Teleton GA202 was £30 and although technically similar wasn't as refined. If I remember there was a Linton turntable. It might have been a BSR HT70 or a Garrard. Linton One speakers were slightly better if making a system. The Two seemed cheaper build. The sound is very like the valve Leak amplifiers. The transistor versions are very like the 1961 Tobey Dinsdale design.
Two diode half-bridge (with a different direction of the diodes). It can be replaced by separate diodes. If switched on by a bridge, replace by a diode bridge in the corresponding connection.
.... Unfortunately I can't download the manual without registering on the site and the registration page is broken.
You'll find more reference material for comparisons at the links below, though in his writings Paul Kemble states that the Wharfedale Linton was a Delta 70 though how accurate a statement like that can be is uncertain with different controls fitted etc. As per Galu's remark, nothing referring specifically to Linton mk 2. It would be interesting to check part numbers of the semis, see if they are Japanese or Euro types (BC,BD etc.)
Leak Manuals
A Paul Kemble web page - Leak Stereo/Delta designs.
