Simple 5670 tube based line stage design help
Hello,
NEWBIE on board😉
I'm building a simple 1 tube preamp based on 5670 tube (see the attached drawing) and would appreciate any suggestion for getting the best out of it.
with any lower cathode resistor than 2K I'm getting distorted output.
Any suggestion from experienced members will be appreciated.
That cathode resistor is much to big.
With 5mA the tube needs Vg=-1,4V , gives Rk = 1,4/0,005 = 280Ω
Take 270Ω (280 hard to find, 270 is fine).
You get a gain of ~10x and if you decouple the cathode resistor ~15x.
Mona
Thanks but I’ve done this calculations before and tried 250 Ω and discovered that any value below 2kΩ gives distorted sound.
Any idea why?
You might be overloading it with the input signal. Higher cathode resistor value allows for more input, but at the same time the linearity will be much worse.
But anyways you're using the tube far outside its linear region, 150V B+ and 6.8k load are both too low.
Another question, I would like to add a volume pot, should I put it at the input or the output?
100KΩ or 50KΩ ?
Both will work. And the input cap isn't really neccessary.
The source is a DAC output.
According to the tube data sheet 150Vdc is okay, correct me if I'm wrong. considering that at the moment 150Vdc is what I can provide what Anode resistor should I use? (tried 10K with the same results).
Doesn't really say anything.
If it has typical commercial 2Vrms (2.83V peak) output, it will indeed overload the stage with 1.5-2V bias.
That's the plate voltage, not the PSU voltage.
I would strongly suggest finding a way to provide higher voltage (there are voltage doublers and stuff) or using another tube that is more happy working with lowish voltages (6922 or something).
If it is impossible, then I'd probably go for something like 18-22k with 510-750 Ohm cathode resistor respectively.
And if you have 2Vrms input indeed, you'll need to drop it by half - you can use, say, 50k volume potentiometer plus the 47-51k series constant resistor before it.
Plate impedance in the datasheet does not mean use a plate loading resistor equal to that value. The common suggestion is that if your plate loading resistor needs to be at least 3x plate impedance to get reasonable audio performance.
Output impedance will be way too high to be useful as a preamp. Adding a second tube or adding a pair of mosfets to buffer the output can solve this issue.
If I understand you correctly I'll have to use a high wattage resistor to lower the 330Vdc to an acceptable 250Vdc level for the 5670 tube as it's absolute maximum rating is 330V.
No. The maximum plate voltage is the voltage across the tube with no signal.
Your plate resistor will drop a considerable amount of voltage, so you need to measure the voltage at the plate of the tube and subtract it from your cathode voltage. If the number is less than 250 with no signal, then you are fine. If it is above that, then yes you would need to find a way to lower your plate voltage.
No, your transformer is producing absolutely the correct voltage for a nice cathode follower output section of a tube pre.
Forget about this5670 tube for high- freq. Use a nice and available audio double triode like 12AU7 or 12AT7 and build a well known two stage line amp like every other good tube audio designer did. That provides you with a low output impedance that you need and it will fit well into using your transformer.
The resulting distortions may occur because of impedance matching problems with this poorly designed circuit you show in the first post.
Try to understand how to design a good tube amp stage by reading books first.
Without ANY theoretical knowledge nobody has ever build a real working audio tube amp. And you won't do either.
So first get the basic knowledge by self studying. Then build a circuit and ask when questions occur. Not the reverse way. It won't work out.
So, we'll assume you have 300V of B+ and call the Rp of the 5670 about 7K. We'll put a red dot on the curves for the 300V. If we load the tube at about 3x Rp, we'll call that a 22k resistor. The maximum amount of current that can be drawn through a 22K resistor from a 300V supply is (based on Ohm's Law) 300V=I*22000 which is 13.6mA. We will put a green dot at 13.6mA on the vertical axis.
