WAF Audio Najda reviews
Oh i search a lot, but i havent seen any proper reviews yet. Would be good to have some in a dedicated thread.
There is a review on youtube in French by "jipihorn". He like the board a lot and some of his criticism has been included in the board version 1.3. He performed measurements:
noise: - 120 dB after the analogue DAC section
harmonics: 2nd and 3rd harmonic -102 dB higher harmonics well below -120dB
THD: between 0.001 - 0.004% depending on frequency
jitter: +/- 5 nanosec
The values are from a youtube vidoe from "jipihorn" in French - I hope I understood correctly as my French is a bit rusty. The tester in the youtube video likes the Najda board, especially as the price is competitive. One thing I am a bit concerned about is that while the sample rate can be 96 and 192 kHz for improved DSP calculation precision, the audio bandwidth is limited to 24 kHz by an internal sample rate converter FIR (?) filter, so 96 kHz source material will be filtered to 48 kHz. This probably is not a big problem (Shannon theorem) and may even protect us from intermodulation distortion of supersonic frequencies in the power amplifier. The noise and THD seems to be very good, and while the jitter is not exceptional it is also good enough, as even the listeners heartbeat introduced larger jitter. I really like the flexible gain structure of the board and the analogue volume control! Very tempted to buy a Najda.
WAF Najda software and documentation
Does anyone have the Wroclaw Audio Force Najda software and/or documentation (to include housing cutout dimensions)?
if so, could someone burn it to disc to be mailed to me (Poland)
I have a Najda, in "kit" form (i.e. parts, no housing),that I (finally) intend to build and put "on-line")
The WAF website has long-since been taken down.
thanks,
John
