CCS maxvoltage?
I have a CCS as the schema. But the one above is 10M90,and when the amp starts up the voltage is ca 550v and when running 490volt.
I was thing about the DN2540 it is a 400v device,can it take the voltage?
attachment.php
The upper one is a 10M90 a 900v device,so that one can take the voltage.
the lower is 400v maybe it can take the voltage then,if not maybe I can use 10M90 as teh lower one to.
But I have it built with DN2540 as the lower one so it would be good if it could work wut that one.
How can I calculate how much of the voltage the upper device takes?
In your drawing, there is 2V across Rset. One hopes that an insignificant amount of current flows through both Rstops, so the gate of the upper fet is only 2V above the output of the CCS (for the 10.7mA case, for higher currents it won't even be 2V).
The source of the upper fet will be a couple of volts above its gate because it is running the same current and should have about the same Vgs, so now you're at a 4V difference compared to the output of the CCS. That's the boundary for the lower device. The rest gets dealt with by the upper device.
Yes. It can even be a device like an LM334. I've used the DN2540/LM334 cascode as an 1mA temperature compensated CCS to set a voltage across a resistor as a reference for a high voltage shunt regulator.
Okay thanks, That's good news. i have limited Dn2540 only 10 and 10M90s but have plenty of Jfets both high IDSS and Low IDSS types to combine with. Which is better the hi idss (like 2n4391 etc) or the lower IDSS Like 2sk30a ,2sk117)?
On Current sinks i use Hi Idss but in this one I still have to experience..
