Drive level for headphone?
AX tech editor
Joined 2002
Guys, I'm new to headphones but would like to dabble in HP amps.
I know there are many different headphone impedances, from 32 ohms to 600 ohms, maybe even more.
What sort of signal levels do these things want to make your ears bleed? I see numbers of xx mW but I guess it depends a lot on the headphone impedance.
Any pointers?
Jan
I find 2VRMS gives a reasonably loud listening level for most mid-level impedance (50 ohm up to 300) HPs. My DT880s are 600 ohm but also lower sensitivity so really need 6VRMS.
Planars need a bit more grunt as they tend to be at the lower end of the efficiency spectrum.
I know, but for me that is the most intelligent decision, but I appreciate that everybody has his own opinion.
Back in the glory days of HiFi, there was no separated phones preamps, every stereo amplifier had phones output. And that works great.
But I understand that is challenge to make dedicated phones preamp, after all we are on DIY site!
SPL per mW -- 2V RMS with my Sennheiser HD650's would be ear-splitting -Z= 300 Ohms. I have Stax from the 1990's -- have no idea what the drive level is as they work off a transformer which provides the bias. They sound great but I find myself using the Senn's all the time.
Low source impedance ~= low power loss.
That's also a very good list, thanks. It does mean it is hard to build something that is optimum for everything.
Yes, clearly.
There are four main cases.
1. Usual box-in headphones. Dynamical, ~16-32 Ohms, ~100-110 dB/mWt sensitivity.
2. Full-size over-ear, 64-600 Ohms, 100-110 dB sensitivity
3. Full-size inefficient, 10-64 Ohms, 85-90 dB sensitivity.
4. Armature, in-ear and hybrids, 10-64 Ohms, >110 dB sensitivity.
(2)While high-impedance ones no need much current, but could demand voltage headroom up to 10-20 volts, current are low, say up to 50-100 mA.
(3)Inefficient ones require both voltage and current headroom up to ten volts and up to half Amp.
(4)Highly-sensitive ones doesn't demand huge swing, but especially sensitive to amps noise and could demand some current if resistance are low, say up to 1 Volt and 100 mA.
(1)Common droplets are somewhere inbetween and needs some dozens of mV to be driven, so, say, again up to 1 Volt and up to 100 mA.
Join 1+4 pair if you can provide low-noise, and add voltage or current steroids for 2 and 3 cases.
Also, keep in mind peak-factor and some, say, 6 dB margin in case of high-dynamic range music material.
Usually users can heat up to some minutes and then roll back volume. This allows to feel the power or saturate emotions.
