Why not? Looks good! Should sounds good too!
Since it is a no NFB design, do you need two stages of voltage gain? I would consider using a higher u triode but use a one stage voltage gain.
Could it be a plausible project?
You have 72.5v going through 100R cathode resistor.
I don't know if you can get all that gain with a single tube that also works well with that voltage ... 5963 is still a very musical and little microphone tube.
Lot of 6s19p
6C19P x16 OTL回路: オーディオルーム
ƒ}ƒbƒNƒgƒ“‚n‚s‚kƒAƒ“ƒv‚l�|‚V‚r‰ü‘¢‹L
非ITブログ>> ブログアーカイブ >> OTLアンプ
I have the 6s19p 32 pcs. Should you ever try, there is no transformer here - one problem less - there is no sound tinting element.
What your opinion?
satsek18
Oh OPT again and with the swarm of 6s19p. Maybe you have tried these circuits?Could it be a plausible project?
What your opinion?
satsek18
What your opinion?
satsek18
I think the Japanese are always one step ahead ...
if you already have, like me, a good OT and a powerful power transformer with those data, the rest is really very cheap.
- Tubes / Valves
- PSE 6S19P
