I would like to test a TPA325X with the PFFB.
I can help 😉 Send me private messages
Thank you daniboun.
I looked at the Post-Filter Feedback document. The tables show that the distortion rates are much lower. I would like to test a TPA325X with the PFFB.
DrMordor is very cool guy ! He made some TPA32XX based on 360 Customs spec. You can trust him )
explain ?
Sorry, had to check something out.
I think you may be confusing DrMordor with doctormord. Doctormord is 360Customs
I know and I am aware )
DrMordor is from Russia and I keep on saying he is very cool and very sociable.
I had the pleasure of seeing his creations and he has a less scientific approach than most of the members here, but he is still very good!
Daniel thank you))))
I'm Doctor Mordor))) From Russia
DrMord from Germany.
You're welcome Bro ) take care and keep on sharing your great job 😉
Hi, as shown below, I own a dual mono IRS2092 Board fully discret components and I also own many TPA32XX boards.
This IRS2092 is particulary great and a found the soundstage being very very good and absolutely dead silence between tracks. I agree with DrMordor, I think anyway that the high end TPA32XX (360 customs for instance) will be better than the top end
I tested some IRS2092 modules, this is one is my favorite (Nichicon and Epcos caps, speakers protection etc)
(I hope you don’t mind asking about your experience from four years ago)
What are those IRS2092 modules, and where did you get them?
I gather they are populated so “just” need a case + mounting etc
Did they come with a PS? (well two as it’s dual mono)
do you recall a choice of different voltages, to take advantage of the potential power
Are the output devices IRF Infineon IRFB4227 HexFETs ? …as used by ZeroZone’s favourably reviewed IRS2092
Cheers
🤣🤣🤣DrMordor is very cool guy ! He made some TPA32XX based on 360 Customs spec. You can trust him
Single ended class D cause power supply pumping which can affect performance, 3255 is a bridged configuration which eliminates this.
- Class D
- IRS2092 Modules VS TPA3255
