LOL yes lets drop 95% / 99%🙂
Hmm that do maybe make some sense, you do lead any heat away with fast evaporating fluid, much faster and better then any oil. I do in fact intend to try, why not take advantage of a great tip? 🙂
Have you ever tried to use cutting oil, you know the type that smokes under smallest amount of heat?
LOL while I am at it, any tips on getting perfect round holes in aluminum on a drill press?
Avoid skitting, triangl-ish holes, avoid burrs and so on
But inflammable alcohol is?Having water splashing around electricity powered tools not very smart idea.
Also, You describe a cooling effect, not a lubricating effect.
Yes I did also motor oil, oil for sewing machines (yes very liquid one) specific formula used of cutting threads from late shop, cooling liquid for lates etc., WD40 (usually handy in any shop).LOL yes lets drop 95% / 99%🙂
For aluminium I resharpen the bits to have less aggressive cutting angles. Triangular holes is a result of incorrectly set cutting speed for given material with still drill bits cutting angles drilling alu it is a bit of challenge.
Yes it is a trade I willingly making 🙂. Also flammability in my case easier to control than splashing water around mostly woodworking shop.But inflammable alcohol is?
I wasn't planning nor willing spending time to debate it. Don't like it, don't use it, dismiss it as something you "read on internet" 🙂Also, You describe a cooling effect, not a lubricating effect.
The reason alcohol works well for aluminum is not necessarily for it's lubricating properties, it works as a cooling agent to reduce plasticization of the material at the point of the bit where heat is generated. If you've ever tried to drill aluminum without lube/coolant it usually ends up with a coating of the aluminum sticking to the lead edge of the bit, making the hole get ugly and imprecise in a hurry.
Mike
Mike
That's what I like so much about this forum... Here I am gallivanting around the threads and suddenly do I stumble upon knowledge I absolutely need but had forgot to ask about! 🙂Yes I did also motor oil, oil for sewing machines (yes very liquid one) specific formula used of cutting threads from late shop, cooling liquid for lates etc., WD40 (usually handy in any shop).
Yes triangle hole can be due to, to low speed or bad drill bit and other things. But often do "high" speed also mean aluminum "welding" it self onto the drill bit, but there do your tip, defiantly help! 🙂
I had, before your tip, thought about using a cup router bit for steel, it makes perfect holes and do not need high speed.
- Design & Build
- Construction Tips
- Bought a thick aluminum amp case and a 19mm powerbutton. Best way to make the hole?
