show me your baltic birch plywood finishes
I'm getting close to putting a finish on some baltic birch plywood speakers and am really curious to see what others have done.
Please post pictures with a quick description of what you used to get that finish.
My mind is melting with all the tips and advice I've read recently and would like to counter that with actual pictures of what the finished product looks like.
I’m looking forward to this, and while we wait Your best finish on Baltic Birch -
Techtalk Speaker Building, Audio, Video Discussion Forum
I will soon build four tham 15 and that is a lot of plywood faces to finish and will use oil based polyurethane for protection since I don’t feel like covering the wood grain. I already own everything but it will be existing to see if I should change my mind.
Probably not since the finish needs the durability I can get from oil/poly.
Painted:
attachment.php
Polished:
attachment.php
attachment.php
Exposed layers of birch ply, tainted and 6 coats of polyurethane lacquer.
It was not to be though, sadly the enclosures cracked on a non glued seam.
Today they look like this which isn't bad either...
I like the clear too, that bottom one though is amazing.
here are the finishes I currently have on scrap wood. The redish (custom mix of cognac and pecan) is a color I like but it brings out some of the fuzzy edges of the grain. The light one on the left is shellac and has a nice gloss and depth to the shine. The top right think one is walnut and I like it but it tends to bring out the splotches the most, even with a pre-stain conditioner on it.
shellac is indeed a very old-school finish. In many ways it is both forgiving and very beautiful, but not a lot of people know how to work with it. You certainly wont see it in a furniture factory or a cabinet shop in 2020... Hats off to your Dad. He does a great spray job with shellac.
Building a TM standmount with Baltic Birch
The bevelled edges look nice. I've decided to make them a "feature" of all my designs henceforth, till I hit some other new idea. 😀
A slim 3-way floorstander with organic curves
I decided to push the limits of Baltic birch to see if it would hold when rounded with a good large bit which would shave off finely tapered curves off its edge. It worked -- I got amazing organic curves on the front baffle edge without any chipping of the ply. The roundover bit is shown -- it's not circular -- it's an elliptical shape of the kind used for rounding banister railings.
Photos of the speaker include the raw-ply and after-PU-polish states.
