DIY Marble Monitor
Hello fellow DIYers :D
I proudly present my 100% diy nearfield Monitors.
After nearly 2 years of prototyping, designing and testing they are ready.
My goal was to design more or less cheap active nearfield speakers.
I compared them to Genelec 1029a (which i really like),
and they performed better then expected, they sound awesome. :D
They are powered by an 50VA 25V torodial transformer, with an added
5V winding for the DSP.
They are bi-amped with two self oscillating class-D Modules,
and controlled by an ADAU1701.
Woofers are 5" Faitalpro 5FE120, amazing and cheap (<30€).
Tweeters are 1.3" soft dome LAVOCE TN131.00 (<15€).
I also added an extra switch, i call it "HIFI mode", which boosts the lows
and the highs. :cool:
The front is made of 20mm South-Tyrolean Marble, wood is cherry,
and th br-channels are made of mdf.
Since i got the marble and wood for free the total cost for 1 speaker was
aprox. 80€ (working hours included <5000€ ;) )
Since i dont have access to an anechoic room, i used the silence outside due
to the corona quarantine here in Italy to measure and adjust the speakers. :p
The neighbours probably got crazy after 2 hours of sweeps :D.
Here are some PICs:
attachment.php
attachment.php
attachment.php
attachment.php
attachment.php
The measured frequency response after adjunsting with the DSP:
attachment.php
Maybe i will replace the transformer with a flyback SMPS, and place everything on one PCB...
Lets see ;)
Thx, the ports are just beatuful in the dark, because the light shines a bit through the marmor and makes it glow like its on fire.
I didnt make any off axis measurements for 3 reasons:
1: I am always sitting in the Sweet Spot when i am mixing
2: I didnt wanna disapoint myself :D (bc that waveguide is really deep like u saw) so probably a problem off axis.
and i dont wanna grind this marble again :rolleyes:
3: I dont have proper measurement equiptment to make a ideal measure.
Here is the fr with 1/12 smoothing:
But i cant say how much comb filter effect comes from walls, and ground outside.
attachment.php
Nice work!
I think a little look at off-axis is a good idea anyway, since you have used a DSP you can make some accounting for this in the crossover (getting a balance if there is a null or bunching up) though, I appreciate you are using on-axis it is always good to know :)
The 1029a is my favourite speaker (that I've heard) and I've owned a few 1029a units in my time, the modern class-d Genelecs don't seem to measure up IMO though I haven't heard the latest biggest and baddest ones of late.
Which DSP board did you use?
I will definitely take you recommendation and try the Faital and La Voce drivers.
Founder of XSA-Labs
Joined 2012
That looks great. Very nice looking. I think Perceval has some speakers made from granite. All walls and not just the baffle. Marble looks very pretty though. You could make some mean waveguides with this stuff I bet. With elbow grease and hand tools - anything can be done. Just look at Michaelangelo’s David :)
You can buy a 50w or 100w Class D amp with the ADAU1701 built in. Just use AD’s free SigmaStudio DSP software suite to program it. Making a DSP Class D powered active monitor has never been easier (and cost effective) for the DIYer.
Dayton Audio DSPB-250 2x50W Class D Audio Amplifier Board with DSP
Or use these with your own amp:
Dayton Audio DSPB-K DSP Kernel Board and DSPB-KE Kernel DSP Expansion 2-In 3-Out
Dayton Audio DSPB-ICP1 In-Circuit Programmer USB
I made my own version ;)
ADAU1701 + TPA3116
attachment.php
Can be used as stereo amp, or 2 way with balanced in.
on my version just 4 GPIO´s are accessable because i dont need more.
Only problem, i placed a 25Mhz quartz instead of 12.288 MHz.
but i already replaced them.
Boards are made and assembled by JLCPCB, price ~13€ per piece (without shipping) :D
Much cheaper than the parts express version. :p
ADAU1701 + TPA3116
attachment.php
Can't see the picture ....
Super nice project.
The amps are the discrete UcDs from your other thread right?
Cool project :up: :up: :up:
How did you model the driver aperture shapes? Do they interact much at all with the response?
I've some Celestion Kingston bare cabinets that I need to design some front baffles for and dont really know how to do it, or what difference the shapes make..
Fantastic that you've been able to CNC marble... with a DIY CNC machine?
Cant say much, since i use them as nearfield monitors i didnt measure off axis, but on axis the apertures are working well.
The cnc (made with aluminum profiles) did a great job with the Marble.
here again the pic of the new amp+dsp boards:
